My $3,500 353sbc 1000hp build ( Cheap Thrills )
Old Mar 20, 2014 | 06:39 PM
  #101
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: My $3,500 353sbc 1000hp build ( Cheap Thrills )
Originally Posted by project89
i can find out for ya when my new 4 inch cowl hood gets here cause then ill know what size box it has to go in , summit is charging me 99 bucks for shipping so it would prolly be around the same
I can take a pic or something of the box my hood came in if you want...it's in my garage..
Old Mar 20, 2014 | 08:20 PM
  #102
project89's Avatar
would need to know what size the box is to calculate shipping
Old Mar 20, 2014 | 11:26 PM
  #103
project89's Avatar
willie just so u know the hood needs to be tweaked a lil bit , and i do have the louvers for it , some of the mounting studs are broke though
on the driver side it sits a lil higher in the middle of the hood , should be easy enough to fix
if ya want it and shipping isnt killer u can have it for the cost of the shipping only
Old Mar 21, 2014 | 08:37 AM
  #104
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Sweet, sounds like a plan. I was thinking of turning the louvers into heat extractors for the turbo build. A little tweaking I can deal with. Just let me know when you find out
Old Mar 21, 2014 | 12:33 PM
  #105
Confuzed1's Avatar
Car: 83Z28 HO
The box is 64"x66"x12" deep.
Attached Thumbnails My ,500 353sbc 1000hp build ( Cheap Thrills )-image-4127388423.jpg
Old Mar 22, 2014 | 10:23 PM
  #106
project89's Avatar
hit a snag with getting the motor in the car , the plan was to reuse my old turbo system till after the car gets painted and ten swap over to the new headers and gt3582's
well my old headers no longer fit as u can see in the pics , i need to cut the wastegate tubes and move them , not a big deal but we had no gas for the welder.
so next weekend i will fix the headers and drop the engine in , and also build the parachute mount
work may slow down on the car though now that i have a 2 wheeled transportation
Old Mar 30, 2014 | 01:53 AM
  #107
project89's Avatar
well engine is complete and wraped back up in the engine bag , car is also in the shop and i will be taking time off of work to complete it , first order of busniness is to rip out the old hacked up harness i bought and completly rewire the car and the standalone ecm to make it much neater and more professional looking
once i rip out the old harness i will strip the engine bay and paint it with the chassi black paint i picked up the install the engine and finish the rewiring
the goal is to have the car running and ready to go by next weekend
Old Mar 30, 2014 | 08:21 AM
  #108
Confuzed1's Avatar
Car: 83Z28 HO
Engine looks great! Should be a rocket, but I hope your tuning is in the ballpark!
Rewiring, painting and installing and tuning by next weekend? Now there's a lofty goal!
Old Mar 30, 2014 | 08:30 AM
  #109
project89's Avatar
will only take 20 mins to rip out all the wiring under the hood( theres not alot there) , and about 2 hours to run the new engine haness
the chassi paint will take a full day , getting the engine bolted back in is a breeze , but i need to fab a th400 and tq arm mount.
i have a base tune that should be close but ill be driving it with no springs in the wastegates at first , without the springs it will only make 3-4 psi of boost which even if the tune is off by alot wont hurt then engine
im still waiting on my 4 inch cowl hood as well
Old Apr 3, 2014 | 01:09 PM
  #110
project89's Avatar
well it runs but motor and trans are coming back out , something is squealing something awful and i cant pinpoint if its coming from the engine or trans
engine has rock steady oil presure and revs good , the trans is a fresh built th400
i was thinking about throwing the 700r4 back in it before i pull everything to see if it goes away
Old Apr 3, 2014 | 01:53 PM
  #111
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Not a belt squeal?
Old Apr 3, 2014 | 02:08 PM
  #112
project89's Avatar
Originally Posted by tylercamaro
Not a belt squeal?
no i even pulled the alternator belt to be sure , i need to check the front bushing on the trans im thinking thats what it is as the converter didnt seat real easy
im pretty sure it is not the engine
Old Apr 3, 2014 | 04:49 PM
  #113
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
gotcha, i had that happen once then it stopped and started pissing tranny fluid, took me forever to put two and two together.
Old Apr 3, 2014 | 05:55 PM
  #114
tommylp88's Avatar
Car: 86' Z28
Transmission: 700r-4
sub'd.
Old Apr 3, 2014 | 06:37 PM
  #115
project89's Avatar
its in the transmission got it dropped and fired the motor and no more noise
Old Apr 5, 2014 | 12:25 AM
  #116
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Is that the Ebay Cheap knock off HSR. I was thinking about getting it but I was worried about the runner port size. I was going to mate them to AFR 210s. But I'm leaning towards LS swap
Old Apr 7, 2014 | 06:02 AM
  #117
project89's Avatar
yes it is , it will goto a 1206 without issues , and apears it can goto a 1207 as well , my heads are just under a 1206 so thats as far as went with it , i had a second manfold i bought i was coing to cut up to get actual port thickness dimensions but my friend bought it from me to put on his vortec truck
Old Apr 7, 2014 | 09:46 AM
  #118
Confuzed1's Avatar
Car: 83Z28 HO
Great…at least the noise wasn't in the motor! Still kinda sucks the tranny is making the noise though…
Do you think maybe the TC didn't seat all the way and screwed the pump up? It happens….
Old Apr 7, 2014 | 10:07 AM
  #119
project89's Avatar
its possible , ill know this comming weekend as the trans will be torn down then
my built 700r4 should hold up for a lil while at low boost i hope, motor should make 450-475 hp n/a so a few pounds of boost should be well past the 700's limits even being a built unit ,one of my friends is pushing me twards a 4l80e which if the th400 is fine i may sell and swap to a 4l80
ive got 5.5 psi springs in the gates right now , but even with those springs i know that i will have a minimum 12 psi atleast with the log headers , im going to be building up and fowards this week soon as i get over the pnemonia i have, so hopefully i can keep the boost down for now
Old Apr 7, 2014 | 10:30 AM
  #120
Confuzed1's Avatar
Car: 83Z28 HO
With 5.5 pounds of boost, you might be OK. Not too sure I'd feel comfy running it at the track that way however…
Do you trailer the car there or drive it there? In my mind, that's makes a huge difference!
Old Apr 7, 2014 | 10:38 AM
  #121
project89's Avatar
i street drive the car everywere its my llate fall/ spring/summer daily driver , i make 120 mile round trip with it once a week weather permiting
but as far as the track either track is 270ish miles away so i will be trailering the car incase something breaks
rmr up north is 262 miles iirc
and las vegas is 272 miles south iirc
i prefer vegas as it at a much lower elevation
Old Apr 10, 2014 | 05:36 PM
  #122
project89's Avatar
engine is back on the stand , pulled it to paint the engine bay chassi black and to complteley redo the wiring , so far today i got the engine pulled and all the wiring stripped out of the engine bay. mocked up the s10 heater box
tommorow i will paint the bay wire up the heater n and drop the engine back in and start wiring up the ecm
Old Apr 12, 2014 | 04:23 PM
  #123
project89's Avatar
started with a apir of these
and ended up with these
have to refit 1-2 pieces to get rid of some gaps but those are the headers im replacing my log headers with
Old Apr 12, 2014 | 05:05 PM
  #124
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
nice fab skills! i like that your trying to stay with the "cheap thrills-budget build" direction. it also proves that the more you can do yourself, you dont have to pay someone else to do it.
Old Apr 12, 2014 | 06:21 PM
  #125
project89's Avatar
well the 400$ up and fowards crashed into my new nice fabbed valve covers , and the only fix was to notch my valve covers , which i was not doing
so i stared at the long tubes my friend had given me and after looking at them i relized it would be very seay to hack them up and reweld them into up and fowards.
it took about 2.5 hours to go from long tube headers to fully tacked up up and fowards turbo headers
im not going to fully weld them till i get final placment of the turbos in the engine bay incase i need to move any of the tubes around
if anyone is interested in my old twin turbo log headers i will make u a screaming deal on them , if not im going to cut the old turbo flanges off them to use on my new headers lol
Old Apr 14, 2014 | 06:43 AM
  #126
project89's Avatar
well its 530 am on my way out the door to head over and work on the car , hopefully by lunch time i can have everything back in the car and buttoned up, car is supposed to delivered to the body shop by this weekend for paint
this is the color im having the car painted
this pic is in low light conditions
and this is what it will look like in direct light
Old Apr 14, 2014 | 08:03 AM
  #127
Confuzed1's Avatar
Car: 83Z28 HO
Looks nice! Is that like a dark metallic blue? Ground FX the same color or silver?
Old Apr 14, 2014 | 08:33 AM
  #128
project89's Avatar
its basically black with dark blue pearl powder and some small flake in it
the whole car will be that color and then im going to get a silver stripe kit and silver emblems
Old Apr 19, 2014 | 11:09 PM
  #129
project89's Avatar
ok well couple more days and she will be street worthy again
anyways heres whats going on , i need to rework the up and fowards i built just a lil built
im very pleased with them as i could run dual 4 inch downpipes with tons of clearance , but instead of the twin gt3582's i think im going to pick up something like a single 88 mm turbo to use with the up and fowards
so for the time being i cleaned up the log headers and cut the old wastegate stands off since they hit the new valve covers , i think im just going to make new wastegate stands on 45* angles which will make everything clear again
as u can see in this picture the flange on the turbine housing also hit the valve cover so i took a grinder to it to get it to clear
on the todo list is to figure out were to mount the new afpr and run the new fuel lines
adapt the s10 heater box fan wiring to the stock f-body wiring
swap the power steering box out for a manual box
move the intercooler out fowards after cutting the crash bar
wire up the new megasquirt harness
other then that i have some areo mods im doing on the car ive got a custom rear diffuser on the way along with a front splitter
Old Apr 21, 2014 | 05:37 PM
  #130
project89's Avatar
so my new hood arrived today
this is my fist steel amd hood and i love it , look sso much better then the harwood hoods
the downside is mine arrived damaged as u can see below
but big thumbs up to summit racing , no questions asked and they sent out a new hood by the time i was off the phone with them , should be here by friday as the replacement is comming from nv instead of ohio , why they didnt just ship it from nv to begin with is beyond me though
and closeups of the damage
Old Apr 21, 2014 | 08:17 PM
  #131
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Really? I dont see how 4" could run between brake side, valvecover and cyl 7.
Looking good tho
Old Apr 21, 2014 | 08:24 PM
  #132
willexoIX's Avatar
Hey if your only going with one turbo you can donate the other to the second stage of my build just kidding.
I am serious about the single turbo 3.4/3500 hybrid build though, just need to find a good job to start accumulating parts.
Old Apr 21, 2014 | 10:16 PM
  #133
Formula 305's Avatar
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Summits customer service is always good... Which reminds me, I need to call them. I received my axles the other day and one of the axle seals came out of the box crushed
Old Apr 21, 2014 | 10:39 PM
  #134
project89's Avatar
Looking good tho
4 inch clears if u go under the headers
Old Apr 23, 2014 | 10:17 PM
  #135
project89's Avatar
my replacement for the first hood they sent will be here tommorow so its looking ral good for getting the car up and running and over to the bodyshop this weekend
Old Apr 23, 2014 | 11:50 PM
  #136
myslow83camaro's Avatar
Car: 83 Camaro
Engine: LQ4
Transmission: TH400
Axle/Gears: 3.89
When are you hoping to have it out ? I just destroyed my stk LS1 but not before making 609 @ the wheels on 26 lbs of boost @ 5000 rpms it was still climbing but we shut it off. Building a forged LQ4 this time hopefully getting it back from machine shop next week. What r u looking to get at the track ? did u splay the caps ?https://www.thirdgen.org/forums/imag...lies/chevy.gif
Attached Thumbnails My ,500 353sbc 1000hp build ( Cheap Thrills )-imag0003.jpg
Old Apr 24, 2014 | 12:01 AM
  #137
project89's Avatar
im hoping to get it down to las vegas motor speedway in may but relaisticly with what i have left to do it wont be till june , i still have to install the cage and chute + get this this thing tuned
caps are not splayed as it was a factory 4 bolt block , if i build another bottom end it will be a roller block with splayed caps
when i get the tune dialed in and the suspension all good im hoping for low 9's high 8.90's out of it. if the engine stays together it should be capable of that
once i hit that ill back the boost off and let it live a while as a high 9 second car
i want one good pass down the strip out of it and one 200+ mph run on the salt with it then i could care less if it blows up lol
Old Apr 24, 2014 | 08:04 AM
  #138
Car: 83 Camaro
Engine: LQ4
Transmission: TH400
Axle/Gears: 3.89
That's kewl that's what I am looking for with it turned up a low 9 or a 8.99999999999999 would make me happy. I just got the chassis certified
and practiced packing the chute a few times so I just need it back in and a little more tuning then start playing with the suspension at the track.
Old Apr 25, 2014 | 12:46 AM
  #139
project89's Avatar
unfortunatly i have to much to do still to get the car to the body shop this weekend
Old Apr 27, 2014 | 01:56 AM
  #140
project89's Avatar
figured id update this before i head to bed
i got the headers modified and installed for the last time, turbos are also bolted on for the last time
downpipes need to be modified to fit past the new wastegate placement
got the oil presure and fuel presure gauges mounted up
also picked up a massive intercooler out of a diesel , lets just say it takes up the entire front of the car ,makes my 12x32x4 intercooler look small
i also rewired the fuel pumps
pump #1 is on with the key
pump #2 and pump #3 are both ecm controlled and are triggered by boost presure
my antilag/launchcontrol switch has been moved from a toggle to the factory hatch release switch ( no more toggles in the car for anything , so besides some gauges in the car when u look inside it there wont be anything to really give away whats under the hood
on the todo list is weld in a bung for the trans temp sending unit so i can datalog trans temp
modify downpipes
fit the new intercooler
and install the correct spark plugs ones i have now are way to hot
down the road i will be switching to a sequential injection , and cop ignition system
im hoping to be driving the car by wensday or thursday at the latest
Old Apr 27, 2014 | 10:16 AM
  #141
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
looking good sub
Old May 1, 2014 | 08:47 AM
  #142
project89's Avatar
car will be back on the road this weekend !!!!!!!!!!!!
i picked up the last few parts i needed yesterday.
holy crap 31$'s for a bottle of gm e.o.s from the dealer ,ill tell ya what that crap has gotten expensive , so after the next oil change ill switch to royal purple or some other oil that has the zinc in it
also picked up the right heat range spark plugs
up and fowards are for sale they are currently only tacked together so i can change the collector and put whatever flange u want on it for the buyer
Old May 2, 2014 | 07:42 PM
  #143
project89's Avatar
well i should have been driving the car home today ,only thing left to do was finish up the wiring and mount the fpr , got everything done except i didnt see my tps pigtial fall on the floor and i stepped on it and broke it, of course i do this about 30 mins after the only parts store in town closes.
Old May 3, 2014 | 12:35 PM
  #144
splitty's Avatar
Car: 82 Z28
Engine: 370 ci.
Transmission: M 20 4 speed
Axle/Gears: stock open 3.43
This is cool. I am jonesin to hear this thing run.
Old May 3, 2014 | 03:37 PM
  #145
project89's Avatar
im heading out soon to go work on it , if everything goes well i should have some videos up tonight
Old May 11, 2014 | 08:25 PM
  #146
project89's Avatar
i didnt get to finish the car , was about an hour away from being done but we got hit with a pretty bad storm and it knocked the power out.
needless to say theres alot of snow on the ground today
Old May 11, 2014 | 09:06 PM
  #147
That sucks! Hope you get to finish it soon, cant wait to hear it rumble!
Old May 12, 2014 | 10:33 AM
  #148
willexoIX's Avatar
Lol this car is gonna drive like its on snow, lol! Even on pavement haha
Old May 12, 2014 | 10:56 AM
  #149
project89's Avatar
should have it done tuesday night or wensday for sure , tuesday i have to make a 120 mile drive so i dont know if ill make it back in time to work on it
i already told my boss im taking wensday off
Old May 12, 2014 | 11:00 AM
  #150
willexoIX's Avatar
Good timing, my 7ft of 2.5 inch pipe will be delivered today, already got both vbands. Hoping to get started on the dp tomorrow. That and the ic bracket and fan wiring and I should be good to go
