My $3,500 353sbc 1000hp build ( Cheap Thrills )
Old Jan 16, 2014 | 10:54 PM
project89's Avatar
Figured id share my stupid cheap , stupid power build here since most of u guys dont make it into the power adder or racing section of the site
originally i had an l98 ish engine in the car with a pair of 57mm turbos making around 500-575 hp , once winter hit i figured it was time to stop screwing around and make some serious power
the cost of the build includes the turbos, ecm,fuel injectors,headers , not just the engine
the engine consists of a factory 4 bolt 0010 block , gm crank , aftermarket bushed rods , speedpro 10cc dished pistons , off shore copys of the dart pro 1 platnium heads ( 260cfm out of the box) hsr intake
the block has been bored .020 over , and line bored
the crank has been cut .010/.010
pistons are speedpro/sealed power 4423dcp .020 over
rods are scat extreme competition rods rated for 700hp
heads are 200cc runner 64cc chambers with 2.02/1.60 valves
i bought these bare for 400 shipped to my door , these are copys of dart pro 1 platniums and flow 260cfm , and can be ported to over 300cfm
the tpi is ditched in favor of a vortec hsr , i purchased a used nx mainline direct port nitrous system that will be plumped into the hsr
neither has arived yet so ill post pics when they get here
the cam i purchased before i had these heads when i was going to use a set of factory castings heavily ported , its a summit 224/224 @ .050 with a set of stainless 1.6/1.5 rockers.
i do belive im going to change out the cam for a 234/238 .585/.600 on 110 lsa
now i know u are all thinking how in the hell is that going to make 1000hp , on motor the thing should make close to 500 , but to top the whole thing off its getting a pair of p-trimed gt3582 turbos good for about 650hp a piece
the crank is in the block and installed with 2.5 though clearance across the mains.( took 3 sets of bearings to get the clearances i wanted )
this weekend ill be installing the rods and pistons , and assembling the heads.
the pistions have a .002 piston to wall clearance , and rings are going in with a .029 top gap and . 023 second gap
pistures and more to come
Old Jan 16, 2014 | 11:32 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Re: My $3,500 353sbc 1000hp build ( Cheap Thrills )
Definitely sub'd. Cant wait to see this run!
Old Jan 17, 2014 | 06:25 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Adventurous!
Please post results when it's up and running
Originally Posted by project89
....the pistions have a .002 piston to wall clearance .....
Is that a typo? What kind of alloy are those pistons?
Old Jan 17, 2014 | 06:28 AM
project89's Avatar
Originally Posted by 86LG4Bird
Adventurous!
they are not forged , they are hyperutectic they dont need a huge piston to wall clearance , manufacture specs them at .001
should i have bought some forged PROBABLY ,
have i built a single turbo engine with forged pistons NOPE, well one because i had to order custom made pistons
have i ever broken a hyper piston BIG FAT NOPE
My tune has to be right on or i will shatter the piston, with all my years if tuning and building turbo engines i have never had an engine failure related to the tune , hell ive never grenaded one either
if i had an aftermarket block and crank i might have sprung for forged , but hypers have been working just fine for me so im not going to stray from my normal type of setup that i do
Old Jan 17, 2014 | 06:43 AM
86LG4Bird's Avatar
I wish you luck.
Old Jan 17, 2014 | 06:50 AM
project89's Avatar
I wish you luck.
thanks im sure ill need it , this build was originally supposed to be around 700-800 hp , but then i found out the heads i was going to use were trashed
so i ended up with a really good flowing head and intake and going to make alot more power then i originally wanted to , i will admit it will spend most of its life at low boost around 650-700 hp
Old Jan 17, 2014 | 08:00 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
I don't mean you any ill will but at that power level the weakest list will be the stock block, especially when you "turn up the boost".
My NA combo making 670 HP did not survive long with a stock block.
Old Jan 17, 2014 | 08:08 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I thought this motor was already making near 9 sec power?
Old Jan 17, 2014 | 08:17 AM
project89's Avatar
the old motor was making close to mid-low 10 second power on boost AND nitrous (11's on boost alone) , i couldnt get it there on boost alone, upon teardown i found out why, most of the boost was being pushed into the valve covers.i was pushing this thing into the low 20 psi numbers and still couldnt get it there
had it not been for the valve guides and bad valves it would have made it on boost alone
thts the whole reason this one is got some decent heads and a much better intake , dont forget im almost 1.5 miles above sea level doesnt exactly make it easy
Old Jan 17, 2014 | 08:19 AM
project89's Avatar
its getting a main girdle and a good ole crossing of the fingers lol, i fully expect to run over the crankshaft at some point
1000hp should get me around 800-850 wheel
Old Jan 17, 2014 | 09:13 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Do a block fill and it will hold. Guys on turboforum have done similar numbers in stock blocks
Old Jan 17, 2014 | 09:28 AM
project89's Avatar
ive been debating that not sure if a girdle alone will be enough , i live on the edge of the dessert it gets damn hot here in the summer time , im a lil worried about over heating issues on the street
even with dual fans , 3 core aluminum radiator i had a hard time keeping the old motor cool when in boost for a while
Old Jan 17, 2014 | 09:37 AM
willexoIX's Avatar
Those valves were the ones in the vid you posted right? Just wow on that, wrap them with some duct tape and you'll be good to go, rofl!
Old Jan 17, 2014 | 09:39 AM
project89's Avatar
lol yeah the video of the valves moving back and forth over 1/8th inch in the guides , i was lossing all my boost pressure up into the valve covers , it blew my umbrella seals clear up to the bottom of the retianers
Old Jan 17, 2014 | 09:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah you will need a real good cooling system plus oil cooler. Not a full fill maybe half fill. Give it some strength. 800 rear wheel is stout. When those caps start flexing around that lower main webbing is gonna be taxed. Lol alittle extra meat down there in the jackets should help keep it somewhat rigid
Old Jan 17, 2014 | 09:41 AM
willexoIX's Avatar
Damn, I don't think you'll have any problems breaking 10s on boost alone, especially with what it ran with the bad valves.
Wish I had a shop, I just have a carport and shed :/ My dad will probably get one built soon cause his 71 pontiac t37 needs a body off resto and the 455 dropped in
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Lucky you didnt drop one. Mine were moving much less than that but the head guy said i was extremely lucky
Old Jan 17, 2014 | 10:42 AM
project89's Avatar
i was so damn surprised when i pulled the valve springs and found that , the motor didnt smoke at all , and didnt make any funny noises , but u can imagine how much boost i was lossing threw those guides , and i know those valves had to be leaking
Old Jan 17, 2014 | 10:44 AM
project89's Avatar
i dont have a shop , im using the shop at my friends farm , he lets me do my stuff at the shop in exchange for helping him out when he has something to work on
Old Jan 17, 2014 | 10:47 AM
willexoIX's Avatar
That's pretty cool. I know people in NJ, where I grew up, with shops, don't know anyone yet with a shop where I moved in FL.
Old Jan 17, 2014 | 12:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Did it go into valvefloat? Or act like a rev limiter? Mine did. We thought bad springs til i found guides worn and springs tested fine. Reused them on my new shaft rocker system and now pull proper rpm no float no rev limit
Old Jan 17, 2014 | 12:45 PM
project89's Avatar
it had aftermarket springs on it , and i was only reving it to just over 5k so it never showed signs of valve float , i did get the odd pop here and there when the motor was up that high , but nothing that would make me think valves were floating
Old Jan 17, 2014 | 01:25 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Can you list parts along with the prices?
Old Jan 17, 2014 | 08:43 PM
project89's Avatar
i can i just need to gather all my reciepts , i can prolly do that late tongiht
Old Jan 19, 2014 | 08:32 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
K thanks!
Old Jan 21, 2014 | 07:03 AM
project89's Avatar
K thanks!
ive been so busy last few days i havent had time to sit down and get exact prices on everything , im hoping i can sometime today, prolly late tongiht as i have to make a 120 mile trip in about 4 hours
anyways these are the headers im going with , the logs prolly would have done it , but im building the turbo system so it can be transfered over to the 427 down the road and support the power that will make
i was going to build my own but for the price of those and how limited on time i have been latley im just going to buy them
Old Jan 21, 2014 | 10:52 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
'scribed!
Old Jan 22, 2014 | 02:07 PM
project89's Avatar
price list
new parts including shipping
pistons 93.96
heads bare 399.00
perfect circle moly rings 23.74
valve covers 50.26
1.5/1.6 rockers 50.00
cam and lifters 103.97
engine gaskt set 71.24
main/rod bearings 45.00
spiro lox 39.99
scat comp rods 299.99
arp headstuds 99.99
fuel rails 54.99
2.02/1.60 valves 99.99
springs/locks/ret 64.99
studs guideplates 30.99
vortec hsr 365.00
total = 1829.10
missing are some misc items like pushrods , and machine work
pushrods have not been ordered yet as i have to check lenght and machine work comes in around 300 bucks
Old Jan 22, 2014 | 02:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Machine work prices for setting valves up, seats etc?
Old Jan 22, 2014 | 02:41 PM
project89's Avatar
no heads checked out right out of the box on the seats and guides , ill assemble them myself and setup the springs
machine work was for block, might have an added cost for balance job once rods get here. im going to weigh the new pistons and rods and see how much heavier or lighter they are then the old ones , and either machine them myself if they are heavier to bring it back into balance , or send the stuff out to have it balanced if it goes the other way
so far the pistons are the same wieght as the old ones it all depends on the weight of the rods now which im sure are going to be slightly heavier then the old rods
Old Jan 22, 2014 | 03:21 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
price list new parts including shipping pistons 93.96 heads bare 399.00 perfect circle moly rings 23.74 valve covers 50.26 1.5/1.6 rockers 50.00 cam and lifters 103.97 engine gaskt set 71.24 main/rod bearings 45.00 spiro lox 39.99 scat comp rods 299.99 arp headstuds 99.99 fuel rails 54.99 2.02/1.60 valves 99.99 springs/locks/ret 64.99 studs guideplates 30.99 vortec hsr 365.00 total = 1829.10 missing are some misc items like pushrods , and machine work pushrods have not been ordered yet as i have to check lenght and machine work comes in around 300 bucks
That is not bad at ALL! What about total build including turbos and headers and such? I'm debating on supercharger or turbo...later of course lol
Old Jan 22, 2014 | 03:35 PM
project89's Avatar
turbos are 230 bucks each for the gt3582's , headers i built and have around 130 bucks in materials , another 200 bucks in oil lines and fittings , 120 bucks in wastegates , picked up a intercooler kit with tubing clamps and couplers from a local forums for 100 bucks , bov's were 70 bucks for the pair
if u want to go turbo , i have a set of log style twin turbo manifolds for sale in the classifieds , ill even throw in the downpipes
Old Jan 22, 2014 | 04:07 PM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
turbos are 230 bucks each for the gt3582's , headers i built and have around 130 bucks in materials , another 200 bucks in oil lines and fittings , 120 bucks in wastegates , picked up a intercooler kit with tubing clamps and couplers from a local forums for 100 bucks , bov's were 70 bucks for the pair if u want to go turbo , i have a set of log style twin turbo manifolds for sale in the classifieds , ill even throw in the downpipes
Where did you get those turbos from? That offer sounds good, might be a little while before I can jump on it though :/
Old Jan 22, 2014 | 04:17 PM
project89's Avatar
while most arent a fan of them , i am a huge fan of the ebay turbos , the turbos i originally had on the car are 150 bucks each
ive run both the ebay and brand name turbos , even did back to back testing on my v6 car with a 61mm ebay turbo and a garett 61mm turbo results between the 2 were very close , still have the garett on my v6 car though
Old Jan 23, 2014 | 09:58 AM
Mrbanados's Avatar
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
while most arent a fan of them , i am a huge fan of the ebay turbos , the turbos i originally had on the car are 150 bucks each ive run both the ebay and brand name turbos , even did back to back testing on my v6 car with a 61mm ebay turbo and a garett 61mm turbo results between the 2 were very close , still have the garett on my v6 car though
at that price if one failed I wouldn't care! The only thing I'm concerned about is the plumbing and oil lines, I have a welder in the garage but as far as sourcing pieces and spending time welding I'm not a big fan of.
Old Jan 23, 2014 | 11:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Really? Thats quite surprising. I would figure atleast valvejob on the new valves.
Old Jan 23, 2014 | 12:20 PM
project89's Avatar
the valve job on them is really nice , of course when my valves get here ill have to dbl check that everything plays nicely together, but the valve seats are in spec just as if if i did the seats myself, i actually have a valve seat grinder if i need to redo them , i think my one stone is shot though
Old Jan 30, 2014 | 02:41 PM
project89's Avatar
ordered up the stuff for the block fill going to do a half fill on it
connecting rods/valves, new valve springs, spring seats , retainers, should be here mid next week
wont be long now before this thing is together
i also ditched the .550 springs im going with a .650 lift spring since i know im going to swap cams again down the road
Old Feb 1, 2014 | 09:40 PM
project89's Avatar
well i am excited everything will be here in a few days so it shouldnt be long before i can start driving this thing again , then again now that im close to having the motor back together were starting to get snow --- go figure
ive currently got a th400 with brake being built , i really wanted to put a power glide in the car , but then id have to run an insanely numerically low gear in the rear for everyday driving and it would just kill the fun of street driving it , if i dont like the 400 im going to go for a built t56
i got my bar to cage conversion kit ordered along with a bolt on parachute mount.
ive got to order up a bunch of ptfe -8 and -6 lines for the fuel system still but for now the factory lines will get me by as long as the return line can flow enough fuel at low rpm low load , i only currently have enough injector for around 750- 800 crank hp anyways , when im ready to give it hell ill order up the 160# injectors which should be good for around 1,200 hp on e-85 (and just enough on methanol) which will give me the flow safety margin im comfortable with
hopefully my fuel pumps actually flow what they are rated for if not i dont know what im going to do pump wise
hope to be taking the car down to las vegas motor speedway end of this month
Old Feb 5, 2014 | 09:28 PM
project89's Avatar
everything is here , except for the stuff i ordered up tonight ( head studs and head gaskets )
so this weekend ill get the short block assembled , doesnt look like my studs or head gaskets will be till tuesday
i bought 2 sets of gaskets , im going to try a set of .021 mls gaskets first , if those wont seal up im going to switch to the .016 composite gaskets i ordered
normally i run a cheap felpro on my stuff , this way if anything happens it takes out the gasket and not the engine , unfortunately doing this with aluminum heads usually results in a torched head , so im hoping the mls gaskets seal up
other then that i need to pick up a new knock sensor and a few odds and ends ,l nice alt bracket and a manual steering box . if any of u guys happen to have an s10 manual steering box u want to sell let me know
th400 should be done by next weekend , the last thing i need to upgrade is the rear end , my usual choice is a s60 , i think i may try one of the diy ford 8.8 swaps , or i may take one of the dana 60's i have laying around and try to make my own tq arm mount
other then that i was wondering if anyone has experience with the edlelbrock proflow xt manifolds my manifold choices are very limited with the raised runner head , the hsr has some air distro problems when running very high boost specifically the back to 2 cyls , which i can actually solve with a flowed set of injectors and just stick 2 injectors that flow a lil less in the back 2 ports , but id rather get a manifold that doesnt have distro issues if at all possible
i almost bought a set of h-beam rods but didnt feel like waiting so im sticking with the scat comp rods
Old Feb 6, 2014 | 02:30 PM
1gary's Avatar
Gear up/tune for Drag Week tour and even just run it not winning and ya got a new supporter. That is the test of all tests for sure.
BTW-do like what you doing.Got me hooked into checking in and reading your thread.
Old Feb 6, 2014 | 02:51 PM
  #42
project89's Avatar
i do not have the money to do the drag week thing , best i can do is take it down to las vegas speedway , and out to the salt flats this summer
the average cost for me to go racing is about $325 in fuel for hauling the car to and from the track + hotel + entry fee + any other expenses. to go racing for a single weekend will prolly cost me about 500+ bucks
i really do miss living a few miles from the racetrack , no need to pay for hotel room or to trailer the car etc etc
Old Feb 6, 2014 | 02:52 PM
  #43
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
sub'd thats gonna be one nasty 350
Old Feb 6, 2014 | 02:56 PM
  #44
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Also subscribed! This should be a beast!
Old Feb 6, 2014 | 03:00 PM
  #45
project89's Avatar
thanks guys , i do have alot to do to the actual car still as well , chute mount, cage , frame connectors , front suspension and paint
the big one is going to be brakes i forgot to budget for a good brake system
i need to start looking into reasonably priced brake upgrades
Old Feb 6, 2014 | 07:02 PM
  #46
ssgt usaf's Avatar
I am stationed here in las vegas, if you make the trip i'd love to meet up. I have a 1990 IROC 5.7 liter looking to do some basic bolt ons and possibly a miniram.
Old Feb 6, 2014 | 07:10 PM
  #47
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
That makes two of us....well...I don't have an IROC though. LOL
Old Feb 6, 2014 | 08:23 PM
  #48
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
Subscribed! I a cheap skate so I'm all for budget projects that hold together lol. I really want to get into power adders....when I know what the fell I'm talking about when it comes to boost. I've read the tune makes the difference but I didn't know hypers had the tensil strength for 1000 horse! Learn something new everyday...also how does a block fill work...I've never even heard of that....
Old Feb 10, 2014 | 01:45 PM
  #49
project89's Avatar
Old Feb 12, 2014 | 12:51 PM
  #50
Confuzed1's Avatar
Car: 83Z28 HO
So - those are the Scat comp rods? They look nice…actually they look a lot like the Eagle SIR rods I'm running, except a bit beefier.
What's the status? Is it assembled yet?
