Good rocker upgrade for 305
Old Jan 19, 2014 | 08:10 AM
MattGibson1's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.0
Axle/Gears: stock
I have a '89 Iroc with a 305. I was wondering what would be a good rocker upgrade over the stock? My cam is most likely going to stay stock for awhile due to money. But if anyone could give me links or part numbers/advice it would be greatly appreciated.
Old Jan 19, 2014 | 10:32 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Good rocker upgrade for 305
You may be S.O.L. on using 1.6 rockers without enlarging the pushrod guide slots through the heads. The 1.6's move the pushrod closer to the rocker pedestal, and sometimes the slot/hole has no clearance in that direction to run anything more than 1.5's
Can't be sure without checking for yourself, but I considered this a long time ago when I replaced the valve seals and had a set of 1.6 rockers in the garage. The 1.6's made the pushrods interfere and I didn't want to risk elongating the slots without removing the heads.
If you're lucky, somebody who knows for sure about your specific engine model/year heads can chime in and let you know if my caution is warranted. Or.......you could just have a look for yourself
Old Jan 19, 2014 | 11:28 AM
Buddy Norwood's Avatar
in my experience i have never had good luck with 1.6 rocker vs 1.5. Is there any particuler reason you are looking to upgrade rockers? are you looking for more HP without diving in too deep?
Old Jan 19, 2014 | 12:54 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
http://www.summitracing.com/parts/su...6-16/overview/
http://www.summitracing.com/parts/cca-7808-16/overview/
http://www.summitracing.com/parts/sum-g3314/overview/
Old Jan 19, 2014 | 06:24 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
My 305 build. Posi valve seals, Comp beehive springs, Comp Roller Magnum rockers 1.5 and Comp CM rods.
If you're swapping out the rockers, don't forget to add seals. Cheap insurance.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
NinjaNife
Aug 23, 2015 11:49 AM
