piston placement/rod facing
Old Jan 22, 2014 | 03:38 PM
92crimsonRS's Avatar
Car: 89 trans am GTA
Engine: 355
so im about to put my l98 back together and i notice two pistons are backwards. i know one side of the block is forward the other. my block is on the stand upside down and i have all the notches in the pistons facing forward. i noticed that pistons for 3/4 the rods are backwards. meaning if i put the pistons in with the bevel to the crank then the notch faces backwards. also seems that these two pistons have been replaced as the one from no.4 has "1" stamped in it. also have two "7" and no 6.
will it hurt to have the notch face the wrong way? or should i get the rods flipped to the correct orientation?
Old Jan 22, 2014 | 04:56 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: piston placement/rod facing
they face forward for a reason... same with the rods.. otherwise the bearings will be installed wrong.
take your time and orient them the correctly.
Old Jan 22, 2014 | 08:12 PM
Engine: 355
thats probably what ate the crank. well now i have to have the shop flip the rods over.
NZKnight
Oct 15, 2015 02:47 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
