Crankshaft Pully not alighned
Old Jan 24, 2014 | 09:11 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
Hey guys,
I have a 305 TBI with the 6 groove belt system. The crankshaft pully is aligned out from the rest of the pully system by about a groove width. This actually caused a new belt to completely lose one of its grooves. Any idea what could have caused this?
Old Jan 24, 2014 | 09:19 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Crankshaft Pully not alighned
A slipped balancer !
Old Jan 24, 2014 | 09:24 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
Can you elaborate? How would i go about fixing this?
Old Jan 24, 2014 | 09:27 PM
Engine: Lb9
Transmission: M20
It either has the wrong pulley from a truck installed or the balancer has failed. the solution would be replace the defective part.
Old Jan 24, 2014 | 09:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Nighthawkf-117
Can you elaborate?
Take the crank pulley off and check the cond of the balancer
Old Jan 24, 2014 | 11:21 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Also check that the balancer is fully on the crank snout-if it isn't tightly seated against the timing sprocket,pulley/belt alignment will be "off" and the sprocket could be slightly loose and"working"on the crank snout-wearing on it..
Old Jan 25, 2014 | 12:51 PM
stickySC's Avatar
Car: 03 Gmc Sierra ,85 camaro, astro
Engine: 305,
Transmission: a4
I just replaced my crank pully. "went with a hardened steel one" after install I noticed I still had my belts with a lot of travel/ bind??/, and the drip from the waterpump. pulled it. about to go put it back on. its been below freezing every day here lately. I might go ahead an replace the harmonic.. I feel like I might have this issue.
hope I don't have to replace any freeze plugs.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
bryaniskoo
Oct 1, 2015 03:18 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
