Vacuum leak? Intake leak?
Old Jan 25, 2014 | 09:51 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Hey guys, have a question. On my 87 z28 5.0 tpi, when hit the gas pedal to wot theres a pause in acceleration so i checked under the hood and did it manually on the throttle body and sounds like theres an air leak or vacuum leak when i push on the throttle manually. I had noticed some coolant sitting in the valleys of the intake. Could this point more towards the intake gasket leaking? I did notice that the throttle cable had a slight bend in it, but i dont believe that would be causing it. I did in fact change the throttle body gasket and iac gasket with no luck.
Old Jan 25, 2014 | 10:22 AM
Cuco Witrago's Avatar
Engine: V8 305 TBI
Re: Vacuum leak? Intake leak?
Same problem here I get pauses in my car like that too except I have a 305 TBI any help and I'd be very thankful too
Old Jan 25, 2014 | 04:15 PM
bump
Infested
May 22, 2018 11:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
cstrobel65
Aug 15, 2015 10:19 AM
