Short piston pin height reliability
Old Feb 15, 2014 | 10:29 AM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Is there any concern regarding short pin height pistons? When the pin height becomes so short that the pin intrudes on the oil rings is what I am talking about where oil ring supports required.
Does this cause issues with oil consumption or other wear issues? What about the overall length of the piston skirt in these applications?
I am putting my final configuration plan together and considering a longer than 3.75 stroke. Even with a 3.75 stroke the rod length affects this issue. In general a longer rod is desirable and if there are no issues with pin/oil rings and short skirts it opens up the options somewhat. Maybe a 3.75 stroke with a 6.125 rod and 1" pin height?
I am building a street motor and long term reliability is a high priority. Not a daily driver but a motor that will not be "freshened up" periodically. Hopefully not for a long time. If pin/oil ring interferance is not desirable then maybe I am better off with a 5.7 rod.
strayli
Dec 31, 2022 12:44 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
sandman92084
Sep 12, 2015 10:27 PM
crzycamaro86
Sep 12, 2015 05:51 PM
