Speedo cable pulled out?
Old Feb 17, 2014 | 05:43 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I have my cluster out since speedo wouldn't turn. While driving I see the speedo cable end. The little spindle inside the shield isn't turning at all while driving
So I played with it and it pulled right out. It isn't broken and looks good new actually but the opposite end with metal square end how do I reinsert that ? Just push it back from cluster end and rotate till something clicks or do I have to remove sheath from tranny and reinstall?
I see under the master cylinder is another joint for the speedo cable just a screwed fitting that looks like it should unscrew but hard to get tools in there
Any tips?
Old Feb 17, 2014 | 06:37 AM
Re: Speedo cable pulled out?
Yup, just pushes back in.
It'd be a good idea to clean it up and put fresh grease on it (white lithium works good), and clean all the old lube out of the sheath. Do the same to the other half of it, which since it's in a hotter place, is probably worse.
Most likely the reason it isn't spinning, will be found closer to the transmission.
Old Feb 17, 2014 | 07:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Feb 17, 2014 | 10:34 AM
jjcuff1's Avatar
Thanks I will lube it up. So when I push it back in should I just rotate it with a pair of needle nose and does it click into place? How far should it go in past the metal collar?
When it is engaged correctly should I be able to see it rotate immediately even in reverse? Just looking for ways way to test in garage?
is it easy to get to if I jack driver side up and lean under to look for the tranny cable connection?
Old Feb 18, 2014 | 09:33 PM
jjcuff1's Avatar
Fixed it.
I pulled the tranny side and the wire was all mangled up. $10 at autozone. Little hard to reroute but easy job and works again!
And tip to future users. After new part installed the spindle should move immediatly even in reverse if it is working properly
Eric2ndGen
Nov 5, 2015 01:51 PM
86IROC112
Aug 31, 2015 07:00 AM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
