Coolant jackets L98 ?
Old Mar 2, 2014 | 08:52 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
I have a dumb question. I am swapping out the engine in my 1992 Formula 350 with a bad rod to a 44,000 mile L98 form a 91 Corvette. On the sides of the engine block are bolts that i removed to let the coolant out so I could rotate the engine to remove the oil pan. When removed there was almost a plug like piece that once I pushed on it popped and then coolant flowed out. My question is once I install the engine and refill with coolant will all these "jackets" fill on their own or is there something else I need to do. I appreciate any info or help and as I stated I know it's a dumb question. Thanks!
Old Mar 2, 2014 | 09:19 PM
Re: Coolant jackets L98 ?
Not "dumb"; just part of learning.
What you unscrewed, was the drain plugs; what you pushed on was just a built up layer of crud (rust, scale, schmutz, whatever) that had built up behind the drain plug. Perfectly normal.
They will all fill up when you pour anti-freeze and distilled water into the radiator. (and of course, put the drain plugs back in )
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The crud buildup in the drain hole you pushed out is typical with mileage.
The block will refill fine
Old Mar 3, 2014 | 02:58 PM
PAFORM350's Avatar
Engine: 5.7 L98
Thanks so much guys.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
