Loud POP when starting, then nothing!
Car: '87 Camaro Sport coupe
Engine: Carb 305 V8
Transmission: 5 Speed
Axle/Gears: 3.23 Posi
I just pulled in somewhere, turned my 87 Camaro 305 off real quick. I came back out and turned it over and a loud POP rang out and scared the s#*t out of me, then turned it over again and nothing! Won't turn over, no lights, no clicking, absolutely nothing! Any ideas about what the heck happened?
Car: 1983 Z28
Engine: 385 Fastburn
Re: Loud POP when starting, then nothing!
Any smells associated with said "POP"?
Was it literally a "POP" or a bang (such as metal on metal...or through metal)?
Have you opened the hood and done a visual inspection? (i.e. looked and noticed if anything is off...or clearly not where it should be, or if fluids are covering everything)
Engine: Carb 305 V8
No smell associated with it, everything looks good under the hood. I just took the battery out and it has no juice. Going to go test it but its less than two years old. No clue what could drain the battery in less than 2 mins, or could cause the loud pop. Sounded like a firecracker.
Car: 1983 Z28
If your alternator is shot then the engine would have been running on battery and that would have drained it within a trip or two.
The pop, from what you describe, sounds like a backfire. If it starts and runs fine then that may be something to just keep an eye on and see if it makes a habit of doing it. Could need a tune up
Engine: Carb 305 V8
Never backfired before, I know that sound. After that pop it was just dead. I cant think of anything that could cause that. Im going to get the battery tested and start eliminating causes. I will be in touch when I return.
Engine: Carb 305 V8
Fixed! Just had to reset the computer and system. Got me worried for nothing lol. Thank you for the advice.
Car: 1983 Z28
