spark plug wire boots melt on distributer?
Old Mar 12, 2014 | 05:24 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
ok never seen this before my spark plug wire boots are melting on distributer . weird right? there davis ign. wires 10 mm . boots on end of plugs look fine , I do have msd but never seen this before . anybody??????
Old Mar 12, 2014 | 05:26 PM
gsxrfann's Avatar
Car: 88 IROC Clone
Engine: 305 TBI
Re: spark plug wire boots melt on distributer?
That is definitely a new one for me!
Old Mar 12, 2014 | 05:28 PM
Engine: 5.7 l98
I know its crazy boots are shorter now one cracked uneven and residue left on cap . I thought I was seeing things.... any insight anyone????????????
Old Mar 12, 2014 | 06:03 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
pics or it didnt happen
Old Mar 12, 2014 | 06:18 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
sounds like there was not good contact, making a spark jump and causing heat
Old Mar 12, 2014 | 06:34 PM
Engine: 5.7 l98
i have pic cant upload from google drive for some reason
Old Mar 12, 2014 | 06:49 PM
Engine: 5.7 l98
looks like boots were too long and melted till boot seated all the way down on dist. uggg $100 wires ruined.....
Old Mar 12, 2014 | 08:55 PM
Engine: 5.7 l98
I had a friend suggest the same scenario .. I guess if the boots too long they will push against dist. and make the spark jump creating heat. do you think the heat would melt bottom of boot???? thanks again.
Old Mar 12, 2014 | 09:07 PM
Barlow8869's Avatar
it would sure make a lot of heat, you should be able to take a wire off and look for marks from it arching from the cap to wire
Old Mar 15, 2014 | 03:13 PM
Engine: 5.7 l98
Ghetto bird . just what we need here . comments like pics or it didn't happen don't help . I hope u don't get the same response to your issues....
Old Mar 15, 2014 | 03:22 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
They're designed to handle quite a bit of heat. Are you sure they melted? What about detailing or cleaning under the hood with a chemical that may have chemically damaged the boots? Kinda like when oil gets on the radiator hoses and makes them soft?
Old Mar 15, 2014 | 03:27 PM
Engine: 5.7 l98
No cleaner used. End of boots look slowly melted . and debris left on top of cap (black melted rubber) just a little but its there I will try and upload pics again later.
Old Mar 15, 2014 | 03:46 PM
Lurbie's Avatar
Car: 89 Camaro
One other thought came to mind. Are you still running the AIR pump? Doesn't the AIR tubes go behind the block as it goes to the other bank? If you've got a leak there, it would sure put a lot of heat in that area.
Old Mar 15, 2014 | 03:48 PM
Engine: 5.7 l98
All air removed . when I was 19 thought it was a good idea to cut them out. Lol
Old Mar 15, 2014 | 07:40 PM
Damon's Avatar
Make sure your rotor and the plug contacts inside your distributor cap aren't all corroded away/broken off before you put on new plug wires. Oh, and make sure the rotor is on straight and fully, too. I've rarely seen melted plug wires at the cap. Usually the coil wire goes first in those cases.
Old Mar 15, 2014 | 07:46 PM
Engine: 5.7 l98
I checked dist and rotor both fine. The wires really got me scratching my head though
Old Mar 15, 2014 | 08:03 PM
Damon's Avatar
Yeah, well then maybe the plugs/boots just aren't right for your cap. If it's arcing (even if it's doing so under the insulation where you can't see it), it's making heat.
Old Mar 15, 2014 | 08:24 PM
Engine: 5.7 l98
the only thing I can think of is the boots Were too long pushing the boot up from the cap. the only problem with that idea is that the end of the boots are melted where they touch the Cap and no signs of arc inside the boot
Old Mar 17, 2014 | 02:57 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Well make sure and let us know when you try different wires if it is fixed.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
