89 v6 parts car. Can I use parts?
Old Mar 14, 2014 | 01:44 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
This is gonna sound a little stupid, but I'm curious about some of the parts on this car and whether I can use them for a manual transmission swap. it had a v6 with t5 combo in it, and I wanted to know if the pedals, master/slave, stuff like that would be useable in my 91 v8? also would the 89 dash pad bolt right on to my 91?
Thanks guys.
Old Mar 14, 2014 | 02:02 PM
Eric-86sc's Avatar
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: 89 v6 parts car. Can I use parts?
Yes the 5 spd parts you mentioned will work just fine in your car. Provided both cars are firebirds the dash will be a direct swap. If the 89 is a camaro, you'll still be alright as you can easily sell off the dash to buy a firebird one. The camaro dash brings a premium over a firebird one.
Old Mar 14, 2014 | 03:33 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
The only manual transmission parts you can't use are the bellhousing, pressure plate, flywheel, and clutch disc. Everything else can be swapped over, including the transmission itself. You need a V8 bellhousing, pressure plate and flywheel, and a clutch disc from an early 80's S10 V6 truck. Or you can buy one of the conversion clutch discs online. I had to grind about 1/8" off the nose of the input shaft on my transmission to get it to bolt up fully, but it works fine.
Old Mar 14, 2014 | 05:20 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
just be prepared replace that stock V6 trans after you beat on in behind a healthy V8.
then you get to do it all over again... the right way.
Old Mar 14, 2014 | 06:59 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Key words there: "beat on it". If you don't it will last. Mine is going on 8k miles behind a V8, and that's after 103k miles behind the original V6. They can even be destroyed behind a V6 if ou beat in them. Friend of mine destroyed 2 behind the stock a 2.8 V6. One at 101k miles, the second at 125k miles.
Old Mar 14, 2014 | 07:19 PM
fervernt's Avatar
I forgot to say it didn't have the motor or trans lol, its just a roller. I decided against it, mostly because I didn't have a way to haul it around right now and wouldn't for a couple days. sad though, the seats and dash alone would have been worth the money xD. oh well, I need to stop spending money I dont really have anyway.
1992 Trans Am
May 10, 2023 07:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Aug 6, 2015 08:57 AM
