A.I.R system
Old Mar 15, 2014 | 04:02 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
A.I.R system
So it just came up in another thread of mine and had me thinking. When I was young I cut out the air system and put on headers with out the tubes. I never plugged any of the ports in the motor where tubing came out. Is there any problem with not plugging the ports?
Old Mar 15, 2014 | 04:39 PM
Engine: 5.7 l98
Re: A.I.R system
Old Mar 15, 2014 | 07:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: A.I.R system
Which ports, exactly?
Old Mar 15, 2014 | 07:04 PM
Engine: 5.7 l98
Re: A.I.R system
I believe one ran into rear of engine on passenger side. That's the only one I remember. Somebody correct me if there are any more
Old Mar 18, 2014 | 02:54 AM
Engine: 5.7 l98
Re: A.I.R system
Ttt
Old Mar 18, 2014 | 04:50 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: A.I.R system
If the headers you installed did not have the A.I.R. tubes, then you've got little to nothing to worry about. Assuming that you either left any vacuum lines in place or capped those off is all you'd have to worry about. The big concern would be if you had headers with A.I.R. tubes and didn't have a check valve on them to prevent hot exhaust gases from entering the engine compartment or if those same check valves went bad and got stuck open. Otherwise, you'll be fine.
Old Mar 19, 2014 | 12:09 AM
Engine: 5.7 l98
Re: A.I.R system
No air tubes on hedders. Thanks.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
