flexplate ?
Car: 1986 z28
Axle/Gears: ?
flexplate ?
just a quick question....
I have a 86 z28 with a mild built 350
it has a chewed up flexplate. I believe
it is a 153 tooth..my question is would it be better for it to have a 168 tooth...are there any benefits to going to a bigger flexplate....
Car: 1983 Z28
Engine: 385 Fastburn
Re: flexplate ?
Idk about that but I'd check your starter and make sure nothing is messed up there (unless you know why your flexplate is botched up)
Car: 1986 z28
Axle/Gears: ?
Re: flexplate ?
the flex is trashed because of a high torqe starter not being shimmed right...i have new 153 tooth and new straight bolt pattern starter.or I have a used 168 and staggered pattern starter...just wondering witch would be better to put in.
Transmission: 4L80E/4L80E
168 requires a different starter, and pushes it farther out. May interfere with headers. But, if you have a mini starter, that shouldn't be a problem.
Overall, though, other than a slightly improved lever arm for the starter to turn over the engine, there isn't any advantage to 168 over 153.
84z96L31vortec
Aug 20, 2017 12:16 AM
Stangski09
Nov 14, 2015 01:27 PM
roysatikas
Sep 22, 2015 08:15 PM
