180 Thermostat?
Old Mar 26, 2014 | 02:39 PM
backtothe80s's Avatar
Engine: 350-TPI
Transmission: 700-R4
Axle/Gears: 3.27 Posi
180 Thermostat?
Assuming the PROM is using a stock tune (I haven't gotten that far into this beast yet ), is there any harm is running a 180 thermostat even in the fans don't kick on until 225/235? I would think that's ok, as it would just open sooner, but I always appreciate expert opinions!
My plan is to replace all hoses, thermostat, and the water pump. Since I eventually plan to get into programming the PROM, I'd like to have the thermostat in place that I want. I know it's not a big deal to change it, but if I don't have to do it twice...
The PO replaced the radiator with a "modern" plastic aluminum unit, so I don't need to worry about that, for now.
On top of that, the #1 fan seems to kick on earlier that 225 and VATS is disabled (not sure if via programming or resistor bypass), so for all I know, the fan temp may have been reprogrammed.
Thanks in advance!
Old Mar 27, 2014 | 12:36 PM
FandGbody8788's Avatar
Re: 180 Thermostat?
No harm at all with a 180, i run a 160 and mines all stock.
Old Mar 27, 2014 | 12:52 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 180 Thermostat?
I run a 180 but I swapped to a SW555 switch that turns on the fan at 210
Old Mar 27, 2014 | 01:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: 180 Thermostat?
Operating temperature vs power and longevity!
http://www.carnut.com/ramblin/_cool3.html
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Dragonsys
Sep 25, 2015 03:51 PM
Stryker412
Sep 20, 2015 06:59 PM
