Mitchell On Demand Sucks, look where they ditched me on a flow chart....... Need help
Old Mar 30, 2014 | 07:08 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
So, im following a Flow chart.. (worst things ever when not complete.) So I got a 32 code (EGR OPERATION). Im doing a circuit test. Im on Step 3; ignition off. disconnect ECM. Probe EGR harness terminals A,B and C with test light connected to battery voltage. If test light is now off ECM is and thats all it says. no arrows nothing. the flow chart ends here. and there is nothing else........ i used a volt meter, and i have no DC volts. So the Light would be out...... But what does this mean? Bad ECM? Good ECM bad EGR Valve??? Thanks Guys for any help. Ive tried searching and searching and i cant find a thing.... Thanks Again!! - Nick
1991 Camaro rs 3.1 Auto
Old Mar 30, 2014 | 09:03 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Mitchell On Demand Sucks, look where they ditched me on a flow chart....... Need
I just checked Mitchell, I cannot copy the code 32 EGR test, but I read it and it seems fairly simple.
Disconnect the EGR connector, and apply 12v to terminal "D". Then, alternately apply ground to "A", "B", and "C". In every case, there should be a change in idle speed. If yes, valve and passages are OK. If no and passages are clean, EGR valve is toast.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
