More get up and go?
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
More get up and go?
Hey guys,
I have a 82 firebird with a 305 with a 700r4 (will have th350 soon). It also has 3:73 gears. Is there anything it can add or do to give the car a little more get up and go?
Car: 88 IROC Clone
Engine: 305 TBI
Re: More get up and go?
You could re gear it. That will give you more torque but you won't have quite the top end speed. Also, I have heard that the 700r is a good tranny when built right. I am getting ready to build mine and put a manual valve body in it.
Car: 1983 Z28
Engine: 385 Fastburn
You have good gears, and both those tranny's are good (partial to the TH350 myself). Though honestly you may want to consider going down to 3.42's or maybe even 3.23's if you are getting rid of your overdrive. You'll be screaming on the highway with 3.73's and 3 gears.
You could do exhaust if you haven't already, or find a nice 350 and do the swap.
Car: 1982 firebird
Engine: 334
Axle/Gears: 3:73
I traded for a th-375 with a shift kit. My 305 is very snappy compared to other ones Ive been in. Its a 334 stroker with aluminum heads.
Car: 1983 Z28
I have a 2200 stall in my car as well, it's very streetable, should work well for you.
