SETTING TIMING ???
Old Apr 8, 2014 | 07:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
SETTING TIMING ???
setting timing after engine swap . (L03 to L31) dis-connected EST wire , set timing . set at 5 deg BTDC , re-connected EST wire (eng. running) , rev engine , no change in timing with rev's . ECM is stock settings for now . I feel I should see timing change with RPM change . I'm puzzled ? any comments or ideas ? thanks ...
Old Apr 8, 2014 | 07:42 PM
Damon's Avatar
Re: SETTING TIMING ???
I've always shut down the motor, then reconnected and fired it up again. Not sure if it catches the timing wire reconnect in a running state.
Also, just checking here, but you are disconnecting the tan wire with a black stripe at the weatherpack connector that's poking out of the main wiring harness above the heater box, correct? That's the timing wire. Apologies if this was already super-obvious knowlege to you, but some people have been known to disconnect the wrong wire.
Old Apr 8, 2014 | 09:05 PM
UNCLE TOM's Avatar
thanks for the reply . I'm wondering about re-connecting EST while engine running also . I will try your suggestion and see , thanks . any more/other comments ?
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
