Help ignition switch or wire
Old Apr 10, 2014 | 03:50 PM
I Roc Blazin's Avatar
Car: Yellow 86 IROC-Z28
Transmission: Automatic:'(
My 86 iroc wont start ,starter, alternator, and battery are all good. Engine will turn over when i jump the solenoid with as screwdriver but when I turn the key i get power but it dont crank or make any sound. I need to figure it out so i can take it to get tires and inspected so shes on the road Please help and thanks.
Old Apr 10, 2014 | 05:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help ignition switch or wire
Need to check for power at all the points on the stater circuit to see where you are loosing power
See
http://92b4crs.tripod.com/86wiring/dia-pics/30-4.jpg
Start with the NSS on the shifter 1st
Old Apr 11, 2014 | 04:31 PM
See
Ok thanks for the advice. I dont have a test light but i have a multi meter tho, should i test for ohms , volts, or amps and what number should it read?
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
djmarch
Aug 9, 2015 05:27 PM
