91 RS hard to start
Old Apr 11, 2014 | 07:03 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
91 RS hard to start
I have been having a lot of trouble lately with my car not wanting to start on the first try. I usually have to turn the car on and off several times, it almost never starts on the first try. And about 1out of 3 times the VATS will reset and I have to wait five minutes before it will start again. It is becoming really frustrating lately as most times I just want to get in and go and the car won't start. Not sure if it's ignition switch related and if it has to do with the resistor in the key but it's to the point that I am really frustrated with the car, and I'm tired of kicking dents into the door when it does this. If any one has had similar problems or can offer a solution I would greatly appreciate it.
Thanks, Chris
Old Jul 17, 2014 | 07:05 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Re: 91 RS hard to start
Hello, this thing on. Went 3 for 3 on not starting right away. About to set this damn thing on fire. Any help would be appreciated.
Old Jul 17, 2014 | 07:14 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Couple options for you. You can disable VATS ( Do a search, It is very easy to disable ). Or you can go to a GM dealer with your VIN and have the order a new key if you think its the resistor in the key. I would disable VATS first, see if that solves your problem. You can always hook it back up if you want to.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
