88 TBI no spark/no fuel
Old Apr 12, 2014 | 08:41 PM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
ok folks....ive got my baby here. ive owned this car for 14 years.. but anyways she's been parked for the last 2 years and ran fine when parked. cranks good, fuel pump kicks on and fuel pressure but no pulse from injectors or spark. ive done all the basics i can think of, ICM,Coil,Cap,Wires, grounds, checked wires for cuts or mice chewed,even changed the ecm with a spare i had. everything checks out as i can see and no change in condition. probably be something stupid and hopefully someone can point me in the right direction. i would probably stumble across the problem but i dont have a garage or the spare time to fumble with it for a weekend at the moment. ive gotta get this thing moved. any helps appreciated. thanks
Old Apr 12, 2014 | 09:48 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 88 TBI no spark/no fuel
The one thing I noticed missing from your list was fuses . There is one on the fender near the charcoal can which powers the ECM (and thus the injectors) but I didn't think that one also did spark . Also fusable links from the main +12V terminal on the starter that power several different circuits . Could one of those have gone open ?
Old Apr 15, 2014 | 02:32 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I see your list includes coil, is that the ignition coil, or the pickup coil?
Old Apr 16, 2014 | 01:23 PM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Ignition coil and wire i replaced
Old Apr 16, 2014 | 02:07 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Do you have an rpm signal?
Old Apr 17, 2014 | 07:46 AM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Limited on tools where its at right now. But im glad someone mentioned the pickup coil. I forgot all about that. Going to try another complete distributor i have tonight. Thanks guys
Old Apr 17, 2014 | 06:14 PM
robbyho21's Avatar
Car: 88 camaro
Engine: 355
Pickup Coil!
Old Apr 18, 2014 | 03:10 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Pickup Coil!
Cool, glad you were able to fix it. I was pretty sure that was the problem, I think the only things in 88 that would keep the injectors from pulsing is either no RPM signal (pickup coil) or a bad ECM.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
92camaroJoe
Aug 13, 2015 06:07 AM
