1991 z28 305 cranks but wont start
Old Apr 14, 2014 | 10:00 PM
Gabaloo's Avatar
This first started as a random problem, i drove it to work fine, then couldnt get it to start, had it towed home. Week later, did the same damn thing. Now its a few weeks later and it wont start at all.
it cranks but wont start, I can hear the pump go for its couple seconds
I have:
replaced the distributor rotor, cap, and icm, and ignition coil
replaced the fuel pump relay
checked fuel pressure, its optimal
plugged in a code reader, all i got was code 12 over and over and over again, not sure what this means
I dont seem to be getting a spark on the plugs, not sure what this could be from.... I have run out of things to suspect...
any ideas?
Old Apr 14, 2014 | 10:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1991 z28 305 cranks but wont start
Means there are no problems associated with the computer
Read
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Apr 14, 2014 | 10:25 PM
Gabaloo's Avatar
Read
thanks for the info, i will be testing these things tomorrow, i should note I also changed the ignition coil.
Old Apr 15, 2014 | 07:34 PM
Gabaloo's Avatar
so i went through all those tests. it APPEARS the pick up coil is no good. I am having trouble finding out how to get it off of there. I keep reading directions on how to remove it, but none of them seem to make sense....
Old Apr 15, 2014 | 08:20 PM
Gabaloo's Avatar
this is what i am currently looking at... can someone aid me in figuring out how this comes off/out of there?
jhawkeye
May 25, 2022 06:33 PM
Jake_92RS
Jan 28, 2020 10:37 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
