Idle increase in park when pressing brake pedal
Old Apr 18, 2014 | 10:29 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
Hi all, I did quite a few searches but never locked on anything like I'm addressing here.
1987 GTA, 5.7 TPI stock, no mods, 118k on the ticker. Whenever the car is running in park, and I push the brake pedal down, the idle increases a bit. Is this normal, or do I have a small vac leak somewhere? Pedal is not spongy or hard, just feels normal except for the rpm increase. After pedal is fully depressed, idle goes back down to normal.
Old Apr 19, 2014 | 06:03 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Re: Idle increase in park when pressing brake pedal
Check your Booster filter and connection going from your motor into the Brake diaphragm. Sometimes the rubber grommet that the filter goes into cracks or stretches and you will lose vacuum when the pedal is pressed. Also check your hose where it attaches to the valve cover.
Hope this helps, good luck!
Old Apr 19, 2014 | 08:20 PM
lasher_350's Avatar
Engine: 5.7 L98
Thank you, calirocz28, I will take a look at those items tomorrow and see what I find!
Old Apr 19, 2014 | 09:22 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
Yip, sounds like either a vacuum leak or the booster is failing. I think the car will rev slightly to "catch up" with the need for extra vacuum when something in the system is not working properly and you push the pedal.
Old Apr 19, 2014 | 09:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It increases while the pedal is moving? Or while he's held still in mid stroke?
Old Apr 25, 2014 | 07:37 PM
lasher_350's Avatar
Engine: 5.7 L98
It actually increases WHILE I'm pressing down, then at full depression, it revs back down to normal.
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
