1976 block in a 1986 camaro?
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Hi all,
Friend of mine went through some troubles lately with the original engine out of his 86 camaro. He found a complete 76' engine for a good deal. I told him it should work perfect because he already has a 2 piece crank in his original engine. Also, the heads have the correct accessory bolt holes.
Other than that am I missing something that would make this not work?
Figured I'd ask the experts first.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1976 block in a 1986 camaro?
Just a flex plate for a 82-85 two piece rear main
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
The only other difference is the 76 block will have a drivers side dipstick instead of a passenger side. If you are already running headers it is not a problem but the stock manifolds will not work with a drivers side dipstick or so they say.
Thanks for the info. His flexplate is original so it should work fine.
Eric- would you be able to switch oil pans to solve the dipstick issue? from what I remember, the dipstick is in the block on the drivers side and the oil pan on the passenger side right?
Thanks for bringing it up.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
the boss for the dipstick tube is higher up on the block on the 2 pcs engines
Thanks Vetteoz!
I'll let him know.
I'll let him know.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Left hand dipstick can be run with the stock manifolds but will require some grinding on the back of the manifolds and a little flattening of the dipstick tube.
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
ok first off, 86 didn't come with a 2 piece seal, double check to make sure that is what it really is, easy way to check remove lower flexplate shield and see if you can see an aluminum adapter at rear of oil pan, if its there its a one piece seal so if he puts in a 76 engine, the flex plate of the original 86 engine's flex plate will NOT work due to the difference in the rear of the crankshaft. the 2 piece cranks are way different from the newer one piece cranks. if you didn't know that already. he will need an older flexplate or if he is using a manual trans a different flywheel.
when it comes to oil pans they are different as well you can not use an 86 oil pan on a 76 block, the rear of the pan is much different due to the larger rear crank for the one piece seal.
you may already know this, just putting it out there JIC you dont
