Few problems, need help. This car is starting to frustrate me.
Old Apr 20, 2014 | 01:02 PM
TVIROCZ's Avatar
Car: 1987 Chevy Camaro Iroc Z
Transmission: Automatic (700R4)
Few problems here, need help. To start off my car is an 87 iroc z TPI 305. I have problems when I start the car. When I start it it will start then the idle will drop and car will stall. If I keep my foot on the gas for a minute it will run. The cat glows red. I got a new maf relay update part #10094701 to replace part #14078307. I believe it's the after burn relay. That did nothing. The idle was going up and down and the car shaked violently. Also the car sounds like it's misfiring and smells of fuel. I am thinking it's running to rich. Can anyone help me out? I am really getting frustrated. I don't have the time and I am tired dumping money to fix this problem. If I can't fix it I am selling this car and one day buy a new one so I can just get in and drive.
Thanks.
Old Apr 20, 2014 | 02:19 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Few problems, need help. This car is starting to frustrate me.
It is certainly running rich if the cat is getting red hot- it will heat up as it catalyzes more unburnt hydrocarbons (fuel) into CO2. Your computer uses the MAF, MAP, O2 and temp sensors to calculate the amount of fuel to inject, an error with any of these sensors could cause an over fuel condition, or weak/no spark could cause a similar issue. Is it throwing any codes?
Old Apr 20, 2014 | 04:00 PM
TVIROCZ's Avatar
Last time I check it was code 32 I believe. That code that everyone seems to have a problem with
Old Apr 20, 2014 | 05:23 PM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
id put money on your catalytic converter being clogged
Old Apr 21, 2014 | 04:18 PM
TVIROCZ's Avatar
Checked the cat and its not clogged.
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
