Does this test prove that wiper switch is not bad?
Old Apr 21, 2014 | 10:10 AM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
I am trying to diagnose my wiper problems. They were working in high speed only. I did some tests to try and confirm whether the switch was the problem or not. I disconnected the wire connectors from the circuit cover board and wiper motor and then jumped the motor and cover board to the car battery to see if I could get the wipers to work independently of the switch. I got the high speed to work but the low speed still did not work so it was like nothing changed. Does this MOST LIKELY clear the switch as being a problem and I can now focus on the motor and circuit cover board? BTW, after the testing, now the wipers will only move a couple inches up the windshield and go back down so things got even worse!
Old Apr 21, 2014 | 10:16 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Does this test prove that wiper switch is not bad?
Yeah, sounds like a motor issue by what you described.
Old Apr 21, 2014 | 11:47 AM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
I am thinking the problem is in the circuit cover board. I had replaced it with a new one a while back but I may not have put in on correctly. I understand that there is a proper way to do it or it may not work the right way. I need to get more info on that....
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
slade5612
Aug 11, 2015 07:19 PM
