383 Horsepower numbers
Old Apr 21, 2014 | 11:32 AM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I have a eagle stroker 383 kit with stealth ram intake, comp 503 (.510) lift cam, 1:6 roller rockers, Patriot aluminium heads, 10:1 compression. Shop said it should have an estimated 450hp to crank. Car at dyno 286hp/296lbs to wheels . BUT, the transmission was going bad and on dyno blew third gear out. I was wondering what numbers the car should be putting to wheels.
Old Apr 22, 2014 | 07:56 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: 383 Horsepower numbers
my 383 made 465 crank HP 472 ft lbs.. on the engine dyno..
mid 12s at the track confirmed this..
my advise; if the entire drivetrain & exhaust is not optimized for the new engine.. the chassis dyno will tell you...
A healthy 383 needs needs a healthy exhaust system a 3 1/2 collector pipe min.
I used to run a 4" mufflex system with 3" y-pipe to hooker super comp headers.
Old Apr 22, 2014 | 08:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
350 whp wouldnt be to bad for that cam and heads.... On a dynojet. 20-30 less on some mustang dynos but not all. Just depends on calibrations
Old Apr 23, 2014 | 02:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Agreed. My 355 with trick flow heads and the LT4 hot cam made 325 with a conservative advance on a mustang dyno.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
randy210
Oct 15, 2015 03:43 PM
Nervous2
Oct 8, 2015 10:53 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
