Where to get main frame fuel lines
Old Apr 22, 2014 | 09:47 PM
gbettner's Avatar
From: Close to Boggstown Indiana ( out in the middle of a corn field)
Car: 89 Iroc, saved from scrapyard
Engine: 350 vortec w/stealth ram
Transmission: 85 corvette 700r4
Axle/Gears: 3.73 posi
Anybody know best place to get replacement OEM style metal lines from pump hanger assebly all the way up to engine bay? I'm finishing up a stealth ram install with all new injectors and I found a bunch of rust in the lines. Don't want to hook them up to new setup.
The cheaper the better. Thanks
Old Apr 23, 2014 | 09:31 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Where to get main frame fuel lines
http://www.inlinetube.com/clips%20br...fuel/clips.htm
they have the fuel line complete kits oem steel & stainless steel
ALSO I recommend getting all new clips, brackets, screws they sell the kit for that as well.
Note this is an oem exact kit.
If you need more fuel volume to feed at healthy engine 400 + HP you might want to consider
plumbing your own system (larger lines) .
Old Apr 24, 2014 | 01:52 PM
gbettner's Avatar
Thanks for the help! Much appreciated!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
