88 IROC Z
Old May 1, 2014 | 12:28 AM
VAM ' s 88 IROC's Avatar
Car: 1988 IROC Z coupe
Engine: stock LB9...for now.
Transmission: T5 non world class :(
Axle/Gears: BW with 3.73 gears.
88 IROC Z
I have been trying to figure out what type of engine is in this car. I think it has a L48 block and heads with a TPI intake. Would that combo work good.
I have got the partial VIN and suffix code on the front of the block. V0916CHA. The date code is I117. I am still trying to get to the casting number but the engine is still in the car so access is tight. This is a bring back to life project. This car sat for 14 years rusting away before I got it. Until today, I thought it was a L98 TPI. I was not sure what year it was so I started reading some posts and now I am all screwed up with what I found. Am I in good shape or do I need to start over?
Old May 4, 2014 | 12:35 AM
mechanic58's Avatar
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
Re: 88 IROC Z
It's an LB9 305 out of an '88 Firebird.
Should've left it sitting where you found it.
Good luck.
CHA 1988 305 LB9 8th letter of VIN:F 190hp TPI Firebird
Old May 5, 2014 | 03:08 PM
Re: 88 IROC Z
Good luck.
That is what I was afraid of.
Thanks for the info.
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
mustangman65_79
Aug 23, 2015 02:00 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
