problems when filling up.
Old May 5, 2014 | 02:17 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
when i go to put gas in the car, i can not hold the lever wide open ever. only half way. ive always had this problem just dealt with it. what could be the problem?
Old May 5, 2014 | 02:39 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: problems when filling up.
It's nothing to do with the car and everything to do with the pumps that you're pumping at.
If the gas pump is turned up too high then it causes the nozzle to kick of prematurely or when held wide open.
(I used to work at a BP in high school, so I'm not making this up).
Old May 5, 2014 | 04:08 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
im pretty sure its the car because its at all pumps. doesnt matter what gas station i go to. never been able to hold it wide open.
chazman
Aug 28, 2018 03:25 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BurlyChev
Aug 16, 2015 09:08 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
