TBI stalling on tight turns
Old May 2, 2014 | 04:47 PM
RavageTheRoad's Avatar
Car: 1991 RS
Engine: L69?
I've replicated this with right and left turns. I've never completely stalled, but if I take a tight turn even slightly fast the engine wants to die for a few seconds then comes back like nothing happened. The first time I had very low fuel and it did die (right turn) today it happened twice during left turns but didn't die. It's a 91 so I *SHOULD* have the baffled gas tank but this car has some serious previous owner syndrome so who knows
I should mention my engine is an L69 converted to TBI if that makes any difference. No I don't have the old carb, but it's on my list.
Old May 3, 2014 | 04:32 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: TBI stalling on tight turns
Are you sure the TBI isn't original? They only had TBI and TPI in 91...
It could be that your fuel gauge is off and reading that you have fuel when in reality you are very close to empty. Fill it up and eliminate that as a possibility.
Is your steering column loose or wobbly?
Old May 3, 2014 | 07:34 AM
ex-x-fire's Avatar
Maybe the sock fell off of the fuel pump.
Old May 3, 2014 | 08:13 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Of course low fuel level could cause this, but I'm sure the OP can figure out the diagnostics if that's what's causing it. Since it's FI and it runs good under other circumstances, you gotta think this is an electrical issue.
G force generated during cornering or braking can wiggle a component or wire just enough to lose contact. The unusual thing in this case is that it happens when turning left OR right. I would monitor fuel pressure while this is going on.
Could also be ignition. I had a case with a small-cap HEI where the engine would stall (or almost stall) under hard braking, but would resume to normal right after the brakes were released. The problem turned out to be a rusted pole piece/reluctor in the distributor. It would have no problem generating a switching signal under normal conditions, but would cut out when under higher G force.
Old May 3, 2014 | 08:27 AM
Car: 1991 RS
Engine: L69?
Yeah that's why i mentioned my engine swap, it was originally an L03 car but it had a spun main bearing when I got it. I did the swap on a tiiiight budget and just happened to stumble across an L69 for cheap. It originally came with a CCC q-jet but I didn't have the money or time to delete the ECM so I just modified the TBI intake and threw that on and advanced the timing more to closer emulate the more aggressive spark advance the L69 calls for. The fuel gauge seems to work fine, I've had it for almost 2 years now and have had it on "E" quite a few times with no issue, so this is new.
The column feels pretty good, but what were you thinking of if it was loose?
Dammit... That sounds like a possibility.
That also sounds likely. I had to replace the ICM 6 months ago and the clips on the little wire harnesses were broken, maybe they're beginning to wiggle free... I did replace the dizzy cap but not the unit itself and I do remember it looking pretty well.. seasoned.
Thanks for the replies! Looks like I'm gonna be getting dirty today
Old May 3, 2014 | 10:02 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I had a 92 that the tilt pins were worn out on and if I pulled the column down enough it would shut the car off, more obvious what the problem was than your problem, but thought I would ask.
Glowsock
Jul 24, 2025 03:15 PM
evilstuie
Jan 9, 2020 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
novaderrik
Aug 10, 2015 12:44 PM
