Heat Soak
Old May 4, 2014 | 02:07 PM
BrandonTheZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 350 V8
Transmission: 5 Speed
Heat Soak
I've been dealing with this problem for awhile and I have found a solution but want to know if anyone has followed this method and if it works. I tried a heat shield and heat wrap but my header is so close to my solinoid it still is destroying it. I just want to know if anyone other than the guy who made the post has had any success with this solution.
https://www.thirdgen.org/solenoid
Old May 4, 2014 | 07:58 PM
Damon's Avatar
Re: Heat Soak
Didn't read the link, but I've found that a mini-starter off a later 4th Gen F-body generally cures ALL these types of problems. Being smaller, the starter and solenoind are physically further from the header pipes. Also, the smaller motor in combination with the built-in gear reduction requires far fewer amps to crank the engine over, making it less sensitive to heat-soak problems.
Old May 4, 2014 | 08:11 PM
Engine: 5.7 350 V8
Re: Heat Soak
The only problems I see with doing that is spending the money on another starter and how do i know it will fit and not **** something up.
Old May 5, 2014 | 10:47 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Heat Soak
All of your answers are already in your other thread:
https://www.thirdgen.org/forums/tech...will-work.html
The solution was handed to you. You can argue and "what-if" as long as you want, or you can get a mini-starter and put the issue behind you.
Old May 5, 2014 | 09:54 PM
Engine: 5.7 350 V8
Re: Heat Soak
Well all these people are saying different ones. Do they all mount with my trans or what? That's my problem. I looked some up but idk if they fit or what. I don't want to buy the wrong one.
Old May 5, 2014 | 10:06 PM
Engine: 5.7 350 V8
Re: Heat Soak
I looked up the starter some guy posted and it looks decent but i want to know if its direct bolt on or what?
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
mfp189
Sep 27, 2015 09:25 AM
