Knock sensor and Calpak
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Trying to make sure I get the right parts, yes I did search, came up a bit dry on the first part...
1. What Knock sensor for block# 14093638?
2. Looking for verification I need Calpak#16051636 for a '7747 ECM correct?
Thanks,
RD
Thanks,
RD
Re: Knock sensor and Calpak
RBob, hooked me up with the Calpak info, anyone have any ideas with the Knock sensor?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
KS has to be specific to your combo (ECM / engine ci / TBI or TPI ) ; is not related to the block
see
http://tpiparts.net/82_92_camaro_sensors?b=1
see
Nothing to do with the block? That goes against everything I have ever heard before...
Car: 82 Z28
Transmission: T400
The block is just a dumb lump of cast iron; it has no idea what ECM or intake setup you are using
The knock sensor is a little microphone, TUNED to the specific frequencies produced by a particular bore size. Think of playing a note on a beer bottle; very similar physical phenomenon.
It has NOTHING WHATSOVER to do with the ECM, other than, the ECM is one of the "consumers" of its signal.
If you have a 4" bore block, get a 350 knock sensor. Doesn't too much matter whether you get it for TBI or TPI, end result is the same.
Car: 82 Z28
Transmission: T400
FormulasOnly
Sep 10, 2015 09:07 PM
