Sweet fuel smell
Old May 11, 2014 | 10:11 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Sweet fuel smell
I searched and wasnt able to find anything on this. Im getting a sweet fuel smell coming from near the charcoal canister. Its very strong after shutting her off in my garage. Supposedly theres a vapor canister filter available but from what I have read you cannot replace it and have to replace the whole shebang. any advice?
Old May 12, 2014 | 06:31 AM
Vader's Avatar
Re: Sweet fuel smell
Beginning around 1988-ish (I'm sure someone has the exact year) the EVAP canister lost the external filter pad, making it basically unserviceable. You might be able to force low pressure air back through the purge port and establish air flow back through the carbon bed and dust filter. If you are really ambitious, the bottom of the plastic can could be cut open, then the dust filter cleaned out or replaced, and glue/bond the can back together. Sadly, a junk yard canister that will fit will likely be in just as bad a condition IF you can find one. You could always get a new one for about a hundo: http://www.rockauto.com/catalog/more...246&cc=1035773
Old May 12, 2014 | 10:47 AM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
im gonna try air and see how that goes, then try cutting the bottom if I screw it up then its time for a new canister which should last another 20 years. Thanks.
chazman
Aug 28, 2018 03:25 PM
dyeager535
Aug 28, 2015 08:10 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
chazman
Aug 22, 2015 02:01 PM
