89 305 tpi wont idle
Old May 22, 2014 | 03:51 PM
thomas2213's Avatar
Hey guys I have a question, First I just purchases an 89 305 tpi for a new project, I have never messed with a tpi system before and thought it could be fun to mess with, anyway the car will not idle unless I unplug the maf, when I do the only code that comes up is a 22 which is the tps and going through the flow chart everything seems to be normal. is there something I might be missing. Thanks
Old May 24, 2014 | 11:59 AM
FBOMB90's Avatar
Car: 90 Pontiac Trans Am
Engine: 5.0 Liter
Re: 89 305 tpi wont idle
Put a volt meter on the TPS wires while plugged in. Turn the key on and monitor the voltage while turning the throttle slowly. It's possible you have a "dead" spot in the sensor. Also check your idle control motor for carbon build up.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
