Heater control valve
Old May 30, 2014 | 07:24 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
I just replaced the vacuum hose from the hard line to the heater valve and from the manifold to the hard line going to the heater controls. while idling i noticed that the heater valve was pouring coolant out of it. could this be because i replaced the lines bringing more vacuum to the valve and it couldnt take that much PSI or is it because the valve was old and just busted.
thanks
steve
Old May 30, 2014 | 07:51 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Heater control valve
bad valve, replace it.
Old May 31, 2014 | 08:48 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
simple as that. not drawing too much PSI with the upgraded tubing?
Old May 31, 2014 | 04:10 PM
Lurbie's Avatar
Car: 89 Camaro
simple as that
The engine doesn't draw any more vacuum than it did brand new simply because it has new vacuum lines so you haven't increased anything. That would require mechanical changes like a cam swap. If you had no vacuum to the valve before and now adding vacuum back to the valve, well I guess that could do it, but understand that it did it because the valve was weak or damaged to begin with and moving its internal parts just finished off what was already bad.
Old May 31, 2014 | 05:46 PM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
alright sounds good. i was just thinking with the larger tubing and less restriction it would allow more vacuum to be created. thanks!!
Old Jun 1, 2014 | 12:37 AM
SparksAj's Avatar
Car: 1992 Camaro
Engine: v6 3.1
Transmission: Automatic
The heater control valves and pieces of craptastic plastic. I've had 3 break on me in the past year and a half. First had a small crack and the second 2 had one of the outlets seared right off.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
New2Chevy
Sep 28, 2015 12:35 AM
lakeffect2
Aug 23, 2015 08:44 AM
