just a couple questions
Car: 1985 pontiac firebird t-tops
Engine: 350 with 305 heads
Transmission: t-5
Axle/Gears: 4th gen rearend with 3.23 gears
the motor in my firebird consists of 10066038 casting number block and 376450 for heads. its got a 280/289 Adv. Duration 450/474 Gross Lift cam with gear drive. 600cfm holley carb edelbrock manifold performer i belive. hedman shorty headers and 3" flowmaster exhaust. the bottom end is stock and so is the valve terrain. stage 2 clutch. i know it was built for torque
my question is when i dump the clutch
its fast but if i drive it normal its a turd. any ideas and how do i figure compression ratio. and is there any thing needed so i can run c-12 and or c-16 in my car have left over from last race season.
its fast but if i drive it normal its a turd. any ideas and how do i figure compression ratio. and is there any thing needed so i can run c-12 and or c-16 in my car have left over from last race season. Last edited by blackd-out z28; Jun 9, 2014 at 12:17 PM.
