calling all cam guru's/pro engine builders
Old Jun 12, 2014 | 10:59 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I really don't know as much about cams as I would like to know ... I do know the can is the heart of the engine and determines how the engine is going to perform as far as idle quality ,power band , rpm range etc...as long as the rest of the engine matches the cam ... And I also know the basics as far as what LSA , lobe center , duration , and lift are n what they do ... What I don't know is how the valve timing events effect everything ? ... And
What do y'all think about this Howards HR cam that is in my fully built 305 ?
488/.495 264/270 114lsa 110 ICL
214/218 @.050
TDC overlap: -12
IO: -3
IC: 37
EO:47
EC: -9
I'm also using 1.6,RR so .520/.528 lift
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades. 24mpg @ 2500rpm hwy. 8.80@ 84mph 1/8th on street tires... 8.000's soon
Old Jun 12, 2014 | 11:36 PM
Car: 1991 firebird
Axle/Gears: 4.10
Basically I'm just wanting to know if this is a decent matched cam for my build I wish I would a went with a 112 LSA or kept the 114 with 220 intake duration and I also believe I should a went with a single pattern cam for the aftermarket heads but I already had this cam when I made the decision to get these heads instead of porting and reusing the swirl ports....
Also I guess I'll give a little more info on the build
.030 over 305 SBC 1991 block
Stock bottom end all checked out turned .010/.010 static balanced all rods and pistons within .5g , spin balanced rotating assembly , all ARP bolts n studs EVERYWHERE! LOL .... then everything was checked/mic'd by myself during assembly ... Speed pro hyperneutic flat tops standard comp. Height ...5cc valve reliefs... Melling HV oil pump w/45-55psi spring (pump came with a 90# lol), but it runs about 60+psi @ anything over 1500rpm , Trick Flow Super 23 175cc heads 56cc chambers , block decked .013 .. Plugs .012 down hole w/ .028 head gaskets for perfect .040 quench and around 10.3-10.7 CR ... Summit stage 2 dual plane intake ported by myself and center divider notched 2" wide by 1.25" down (notched so TBI bores can feed both banks) ..... 620cfm TBI unit with 68# injectors @ 30 psi FP ... AWFUL EXHAUST SYSTEM :-/ ...
Summit shorties w/ tiny 1.5" primaries with crappy crush bent bs after that all way back ...
When I get funds up its getting a billet dizzy, hooker super comp tuned length headers , either a 3.5" system into single muffler or dual 2.5" system all way back ...mabey just to the axle idk .... And prolly a small single plane intake so Ivan port match to my heads ... This intake was port matched to the swirl port heads which have much larger runners ... So there's a large step at the manifold to head transition in the wrong direction lol ... So after all this I KNOW there's ALOT left in this little 305 build (don't hate I like being the underdog n doing **** different / my way ... If I wanted 600ft lbs @ 2500 I would a built more cubes ... Thanks ahead of time for any useful info or suggestions ....oh yea its also a 5 speed car with 4.10's out back
Old Jun 15, 2014 | 02:05 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: calling all cam guru's/pro engine builders
Sounds good Rock On!
Old Jun 15, 2014 | 02:41 AM
Car: 1991 firebird
Axle/Gears: 4.10
http://m.youtube.com/watch?v=6OIYOdw_gAc
http://m.youtube.com/watch?v=hXiKkeHSoLk
http://m.youtube.com/watch?v=1-_WLYa2Dks
http://m.youtube.com/channel/UC5O2dInGbDVaMY89XqD_iBg
Few videos a the ole chicken
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
