Lb9 with vortec heads and trying to find a better cam
Old Jun 15, 2014 | 05:55 PM
tazz6989's Avatar
Car: 86 Iroc z / 91 RS
Engine: LB9 / looking for a bbc 396
Axle/Gears: 2.73 both for now
Ok I have a 86 iroc with a 87 lb9 I was thinking of going with a vortec head set up while keeping my tpi the cam I'm looking at is the Lt4 hot cam would that be too much and would it have to be tuned right away last but not least how much do you think it would help this Lil old 305
Old Jun 15, 2014 | 06:25 PM
Linson's Avatar
COTM Editor (Retired)
Car: 89 Formula 350, TTA
Re: Lb9 with vortec heads and trying to find a better cam
ZZ4 cam might be a good choice. crate engine cam, pretty mild.
208/221 duration & 474/510 lift. I have it in my 350 with aluminum Vortecs. I might should have gone with the hot cam or at least 1.6 RRs instead of the 1.5s. that's the way it goes though, youre always gonna wish you'd went bigger or smaller on something.
Old Jun 15, 2014 | 07:20 PM
tazz6989's Avatar
Yea thinks I'll give the zz4 a look
Old Jun 15, 2014 | 08:00 PM
tazz6989's Avatar
Also lookin at this comp cams 08-302-8
Old Jun 15, 2014 | 09:24 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
The zz4 or that Comp 302 is the max I would run in a stockish 305. The LT4 Hotcam, unless you've upped the CR significantly, would run like dogsh!t in it, and would be absolutely horrible without a custom tune.
Even the ZZ4 or Comp 302 would need tuning to get the full benefit from them, especially for idle and part-throttle driveability.
Old Jun 16, 2014 | 12:52 PM
tazz6989's Avatar
Yea I was thinking about boring .30 over but Idk whould love to find a 350 but money's tight with 3 kids
Old Jun 16, 2014 | 03:21 PM
tazz6989's Avatar
I will say this is my first build so I'm still leaning here what would be needed for the compression to be right for a Lt4 hot cam and I will have a chip burned if need be just wanna keep it mild but want a better top end and 195 hp is weak so
Old Jun 18, 2014 | 11:40 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
since youre on a budget, I would find some quality cast flat top pistons.they will go nicely with the 30 overbore you mentioned.plain iron rings work well too. have your stock rods checked .and spring for some ARP rod bolts. you can re use your cast crank if it aint broke . I recommend you line hone the block and check for things like core shift ect. as for decking the block just cut it enough to true it up.no need for you to zero deck it. with all this done you will be right around 9:5-1 on your compression rto.87 pump gas friendly. you should be around 230 or so HP. and 300 ft. lbs torque. no, it wont be a fire breathing drag motor.but it WILL put a grin on your face. AND you should see 20 or so MPGs.
Old Jun 18, 2014 | 12:03 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I would recomeend a 1.56" compression height piston and ZERO deck. It is the easiest way to get the quench correct with the .038-.041" compressed head gaskets that are made for the 305 today. Stock rods are stupid weak in the later model 305s. Get either a set of "X" or "O" rods or a set of powdered metal LT1/Vortec rods.
Old Jun 18, 2014 | 01:33 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
If you're going to pull to motor and change the pistons, just go with a 350. It's cheaper. You will lose compression putting Vortec Heads on a 305. It will be in the mid to low 8's.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
