SS Bolt Set Help Needed
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Picked up an engine SS bolt kit from ebay. (plenum, intake, runners, etc.)
Do I need to add any lube/anti-seize or anything special as they are SS bolts?
Thought there might be an issue with SS bolts on my alum manifold or bolting the runners but need some advice.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: SS Bolt Set Help Needed
I don't know for sure but I put anti seize on my engine bolts or anything going into aluminim. I know steel and aluminium can react with each other.
I also use it on my header bolts and double check torque after a temp cycle
Engine: 4++,350 & 305 CIs
^^^^^^^^^^ Yup, anti-sieze.
