Bad Ignition Control Module
Old Jun 16, 2014 | 08:06 AM
Jcase350's Avatar
Car: 90 Camaro Iroc-z
I have a 90 IROC-Z w/ a 350. This is the 3rd ignition control monitor I have had to replace due to it going bad. If there was a short going to the ICM...where or what would I check for a short...the Ignition coil has 12 volts going to....but the ICM module itself checks out bad....when I test it...it only has .3 volts going to it. Last time I replaced it...it fired right up...30 miles later...it died again. Replaced it again and same thing. What would keep the ICM going bad....also has a brand new distributor on it. Please advise
Old Jun 16, 2014 | 11:29 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Bad Ignition Control Module
Have you been putting the heat sink compound under before installing?
Old Jun 16, 2014 | 03:01 PM
Jcase350's Avatar
Yes...they were both brand new distributors with new ICM's.
Old Jun 16, 2014 | 06:49 PM
morgsie's Avatar
Check that block grounds are in good shape/still hooked up.
Old Jun 16, 2014 | 06:57 PM
Jcase350's Avatar
Are you talking about the grounds that go to the block?
Old Jun 16, 2014 | 11:32 PM
Jcase350's Avatar
Are there any ECM wires that run to the ignition control module or coil?
Old Jun 18, 2014 | 10:40 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
are you using good quality ICMs? not from auto zone or advance? I used the best one I could get from oreilleys BWD select $65. now if your ign coil is going away it can cause all manner of problems.have it checked .and as mentioned go over all related wiring .make sure it all is up to spec.
Old Jun 19, 2014 | 07:05 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Bad/going bad coils can fry ICMs, as well as bad/going bad pick up coils in the distributor.
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
