Fuel pump to sending unit rubber thing
Old Jun 19, 2014 | 11:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Anyone know where to get that piece?
Edit:
Never mind, figured out it's called the pulsator.
Old Jun 19, 2014 | 09:24 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Fuel pump to sending unit rubber thing
It's designed to cancel out harmonics caused by fuel pump vibrations into the steel line. But by the advice of memebers on this board I deleted it and replaced it with a regular piece of FI neoprene hose with no ill effects after 2 years.
If you are determined to replace the pulsator with another pulsator, you can get one from Dorman.
Old Jun 19, 2014 | 09:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Thanks, did some research on it, seems it's a "good idea", but not needed.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
