vortec head and cam selection
Old Jun 16, 2014 | 08:36 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70s) pbr rotors
ok im looking for a awesome cam to run with my hsr vortec build the heads have been opened up to 2.02 intake and 1.60 exhaust ports. i plan on using the stock springs, retainers , and guides i pretty sure the max lift on them is .470 i believe so i was looking into comp cam since they are close to stock lift kinda i would also like to be in the 350 hp range if that matters wanna have a bang for your buck kinda build since i have my son's first b day im planning for him so its gotta meet the budget if its possible
Old Jun 16, 2014 | 09:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: vortec head and cam selection
There was a cutting tool (in the day, probably still available) that you could cut the stems down...I think there was another to enlarge the spring seat as well, would open up a large range of cams and possibly better/more options for you.
As I recall, Vortecs worked best lower lift (good flow through the 200-400 lift range), but were good through 500-525 lift and made nice power.
Reason I mention a about 100 bucks in tools to mod your heads, looks likeyou have some good coin wrapped up into the engine now, why not finish it off right?
Old Jun 17, 2014 | 03:12 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Aftermarket cam and stock springs usually isn't a good idea.
Old Jun 17, 2014 | 06:21 AM
Engine: LR4 4.8
[QUOTE=8Mike9;5779173]There was a cutting tool (in the day, probably still available) that you could cut the stems down...I think there was another to enlarge the spring seat as well, would open up a large range of cams and possibly better/more options for you.
What exactly is getting cut down ????? Is it where the springs sit with rockers ??? When it comes to machining i get lost big time
Old Jun 17, 2014 | 06:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9 3.00
Yeah get a set of springs to match the cam. Is this a hyd roller cam motor?
You ported the heads and revalved them, so do the build a favor a replace stock springs.
Old Jun 17, 2014 | 10:44 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
[QUOTE=soarestransam;5779273]
As I recall, the was a cutting tool then was guided by the valve guides, and you'd take however much off that was needed for retainer clearance when the valves opened.
The was another tool that (used the same way) that enlarged the spring pockets to suit aftermarket springs. But thinking about it, for as long as these heads have been around, it's very possible the manufactures have come up with a spring that works without modding the pocket.
But I think the guides still need to come down, or look into the possibility of offset keepers...I know when running Chevy valves in a Ford Flathead, they (offset keepers) are used.
Edit:
Here's the tools I'm talking about
Old Jun 17, 2014 | 01:13 PM
RyanJB's Avatar
[QUOTE=8Mike9;5779352]
Edit:
Beehive springs fit into the heads with out cutting the pockets.
Old Jun 17, 2014 | 05:50 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Read my Vortec build here.
https://www.thirdgen.org/forums/tech...5cu-build.html
Old Jun 19, 2014 | 09:06 PM
Engine: LR4 4.8
Ok so i got the guides cut down to have a bigger lift cam installed my machinist said the max i can go is about 520 for lift is that correct ???? Also since i dont have a roller block whats a good cam selection to choose from
Old Jun 19, 2014 | 09:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, probably, depending on what he cut, but I think you'e at the top of what the heads will support anyways.
I'd (if I were you) speak with Comp, lunati, etc, and tell them what you have, get a range, ask them for your setup torque and HP curves, let them know everything...running an auto?..will you need a stall converter, rear end ratio...etc.
Let them know the intent of the car...daily driver, drag racer, etc...then mull over the info you get and you'll be better suited to make a choice.
JMO.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
