A/C Restore
A/C Restore
I took the A/C off the car a number of years. All the parts are still on hand. I bought a new compressor, couldn't tell you if it works, but it's either new or gently used. Everything else has been in the car, exposed to everything mother nature has.
So I wonder - what needs to be done to get it to work again? Is it just hook it back up, fill with refrigerant, ad go?
It may not get done this year - we'll see. Too much other work to do first. But who knows.
I appreciate any help.
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: A/C Restore
I'm not an AC tech, but part of it is putting in oil, vacuum out the moisture, see if it holds a vacuum (thus no leaks), then fill with refrig. HTH
