drive train repair question
Old Jun 30, 2014 | 05:31 PM
Gabaloo's Avatar
its a 1991 tpi 305 v8 auto trans so it slams pretty hard entering second gear, just first to second though, also has a few leaks, so i am in the process of replacing bits. this one part however is got me stuck. I BELIEVE its called the slide yolk sleeve, i have attached a picture
that copper colored bit, which seems to be press fit in there. is there any way to remove it, some trick? otherwise you have to take much much more stuff apart, hopefully someone here knows a trick to it..
thanks
greg
Old Jun 30, 2014 | 05:37 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: drive train repair question
Hi Greg
I am 99% positive you must remove the tailshaft cover and have the bushing pressed out (and the new one pressed in) on an Arbor press .
Good luck ...
Old Jun 30, 2014 | 05:45 PM
Gabaloo's Avatar
haha thanks, I guess thats what I get for trying to sell her
was really hoping there was a special fancy Gm tool, but looks like ill be delving deeper into her guts.
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
