1984 z28. Help with MAP and Barometric Pressure Sensor
Old Jul 3, 2014 | 10:28 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Apologies in advance if this is posted in the wrong section.
I just bought a 1984 HO z28. It came as an unfinished project with a newish motor from a 1984 l69 trans am stabbed in and running but far from complete with loose ends all over.
I have been slowly working through vacuum lines and adding/replacing sensors to get the trouble codes to disappear.
Currently I am showing a code 34 that I am assuming is due to a missing sensor that I cannot find. I think it's either a map or a barometric pressure sensor.
I have attached 2 pictures. Can anyone tell me what this sensor is? There is no vacuum line attached. I just pulled the plug for identification only. This sensor is located between the D.S. fender and brake booster.
Second pic. I need to know what attaches to this plug if anything. The wire for this is currently coming out of the harness right under the distributor.
Please ignore the hello kitty band aid. I filleted the end of my thumb and had to keep it clean.
Old Jul 3, 2014 | 11:22 AM
Re: 1984 z28. Help with MAP and Barometric Pressure Sensor
First one is for the MAP sensor. Should be a small hard plastic vac line coming out of that harness, or otherwise near there, as well.
2nd one is baro sensor. Ordinarily mounts to the edge of the windshield cowl about right above the heater hose nipples.
Old Jul 3, 2014 | 11:29 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the hard plastic line for the VAC sensor cannot be found it can be replaced. It runs to the rear port on the carburetor.
Old Jul 3, 2014 | 11:48 AM
RamIt's Avatar
Car: 1984 z28
Thank you gentlemen. New barometric sensor on the way.
colton_carlson
Mar 8, 2019 12:21 PM
9192camaro
16
Feb 3, 2019 12:21 AM
suzuki949
Aug 28, 2015 08:07 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
