Need Help!!! Pls!!!
Old Jul 7, 2014 | 08:13 PM
robskilhs's Avatar
Car: 1990 iroc z
Engine: 5.7L 350
Need Help!!! Pls!!!
I have a 1990 iroc z. Recently the engine and transmission have been rebuilt. Today the car started to act funny, it has low oil pressure at idle, loss of power, sounds louder out of the exhaust, shakes. I am not sure what it could be
Old Jul 7, 2014 | 09:55 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: Need Help!!! Pls!!!
It should have some codes in the SES light with all that going on. Sounds like it lost the correct timing to me for starters.
Old Jul 8, 2014 | 07:12 AM
1gary's Avatar
"Built" is pretty vague.
Old Jul 8, 2014 | 09:12 AM
robskilhs's Avatar
Car: 1990 iroc z
Engine: 5.7L 350
Rebuilt as in remachined block, new heads, new alternator new water pump, new cam, new crank, new pistons, new valves, new fuel rails, new injectors, new plugs and disributor, port and polished intake, some other stuff as well that doesnt seem to come to mind right now.
And i think the guy is right with the timing. It also is now hard to start which is a symptom of bad timing i think. The reason i think it started to act weird is because the bracket that the alternator sits on wasnt on all the way, missing a bolt. So the belt was pulling the bracket a little bit in. I took the belt off and secured the bracket. I think in doing that it must have thrown off the timing a lil bit. You guys agree with that or could it be something else? Also noticed the oil pressure drops at idle
riffsimm
Aug 10, 2003 10:37 PM
boby47
Mar 16, 2003 10:37 PM
Daz
Jan 12, 2003 03:26 PM
logikal6785
Jul 14, 2002 03:34 AM
logikal6785
Jul 12, 2002 01:59 AM
