Ignition Coil Replacement
Car: 89 IROC-Z
Axle/Gears: 9 Bolt Borg-Warner/3.27
So, what's the trick for removing the mounting bracket from the coil? There's no screws just 2 pins that look like they are driven through the outer coil and bracket. The coil bracket screws into a lower bracket with 2 screws beside the distributor.
It's a 88 Camaro 5.7l
Any help would be appreciated. Thanks in advance.
92camaroJoe
Aug 13, 2015 06:07 AM
