Stalling and intermittent ses
Old Jul 19, 2014 | 09:13 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
86 ta 305 fi.
110k
So this happens after its very warm about 20 minute drive usually Highway. After pulling off and driving slow in a parking lot it will stall. Now I fixed the main stalling problem with a new Iac. This seems to be random almost like vapor lock.
I have changed:
New radiator
TThermostat
Iac
Wiper motor
Tires
Most of the tech things done to it. It also has a intermittent ses light and disappears so quick by the time I pull over to check it its gone. I'm puzzled. Any faithful input running 86 octane
Old Jul 20, 2014 | 02:29 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Stalling and intermittent ses
When replacing the IACV did you follow the procedure necessary to reset it ?
Old Jul 20, 2014 | 11:57 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
I believe so I let it idle for about 2 minutes cold after install
Old Jul 21, 2014 | 11:55 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
On my days off this week in plan on wrenching on it and pulling out the Iac and resetting it making sure it's proper and check for possible vacuum leaks
Old Jul 24, 2014 | 11:03 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
if you happen to have a TPI car ,(you forgot to specify) there definitely is a re set procedure for minimum idle air.
Falcon50
Aug 22, 2020 03:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Reid Fleming
Oct 10, 2015 09:56 PM
HoosierinWA
Oct 7, 2015 10:15 AM
