Lifters
Old Jul 23, 2014 | 10:30 AM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Lifters
Those of you with 1 pc rms factory roller blocks, What lifters are you using in your NON STOCK motors?
I'm building a 383 and I want drop in and go durability like a stock lifter but don't want the limitation of one around 6500 rpm.
Sent from my iPhone using IB AutoGroup
Old Jul 27, 2014 | 04:17 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Lifters
Any hydraulic roller lifter will limit your rpm to around 6500. GM uses stock hydraulic roller lifter in there racing crate motor as well as LS motors. If you are going to regularly turn your motor higher that 6500 I would install solid roller. If it is a street motor I would deal with it.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
